Willys Stock Tire Size Question
VWillys
Vince
PA
2021 JL Wrangler Willys - Bright White
Does anyone know or venture to guess why Jeep chose to use Firestone size LT255/75R17 over Firestone LT285/70R17 since they both fit the stock Willys wheels?
The Firestone LT285/70R17 does not appear to be available in OWL or Load C so maybe that's the reason???
Jeep Wrangler JL Willys Stock Tire Size Question Tire Size Comparison
Jeep Wrangler JL Willys Stock Tire Size Question Firestone DESTINATION M:T2 - LT255:75R17
Jeep Wrangler JL Willys Stock Tire Size Question Firestone DESTINATION M:T2 - LT285:70R17
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
285/70/17 is available in load range C in other tires, just not the Firestone MT2s. BFG, Falken, Nitto, Toyo and probably others have them.
VWillys
VWillys
Vince
PA
Sorry I should have specifically asked why they bypassed Firestone branded 285/70/17 in my OP. I am aware that there are other brands this size available in load C.
I will edit my OP
VWillys
VWillys
Vince
PA
Probably the easiest explanation is to keep the Rubicon more exclusive. Having that distinct appearance of larger tires on the Rubicon is important to them.
Makes sense
VWillys
VWillys
Vince
PA
I know this is hard to believe...but not everyone wants a lift and big tires. :) The willy's is a sweet spot between not a basic sport and not a rubicon.
Haha...I'm actually one of those people! However, the 285/70/17 size looks like it could be "just right" for me.
I also like the way the OWLs go with my Bright White Willys.
barberperez
Lupe
Ohio
2021 JLU Wiilys
meh...the 255/75R17's just looked too small on the Willys to me.
Jeep Wrangler JL Willys Stock Tire Size Question 20210304_104806
The 285/75R17 look much better, IMHO.
Love your ride!!!! That color just begs to be looked at. An you tell me if there have been any negatives about going with this tire size? I’m most concerned about running or steering issues. Thanks in advanced
lmendham
Pennsylvania
2021 Jeep Wrangler Willys Edition
Is your Jeep lifted? I like the look of the bigger tires but don't want to lift my Jeep. (I also won't be replacing my tires until the stock tires are worn out) Also what black lug nuts are you using, I'm looking for lug nuts to put on my Willys.
Thank You!
JL MADDOG
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Thank you. I'm a fan of that particular color having had a 4th Generation Ram pickup with the same hue.
As far as any negatives with the tire performance I have experienced none. In fact, the tires are superior to the Firestone Destination M/T units supplied with the vehicle by Jeep. They are quieter, handle better in dry and wet conditions, the vehicle has a softer ride (I did air down the M/Ts but to no avail) and I get much better off-road traction with them.
The only downsides are 1) the spare tire rubs slightly on the stock rear plastic bumper. This was not a real concern for me as I had planned on replacing that with a steel bumper and adjustable spare tire carrier, and, 2) I have a small speedometer error to deal with, ranging from an increase over stock of 1 mph @ 20 mph, 2 mph @ 40 mph & 3 mph @ 60 mph.
JL MADDOG
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Thank You!
The Willys was at stock height when those pics were taken. I have since lifted it for more travel for off-roading.
Jeep Wrangler JL Willys Stock Tire Size Question 20211023_114323
The black lug nuts are actually locking wheel nuts from Gorilla. I went with a full set which includes 4 sets of 5 lugs for each wheel on the ground plus 3 more for the spare & the wheel key. The part number for those is 96644BDX.
CMTAZ
Phoenix
2024 JLURX Anvil
285/75 17 Toyo Open Country AT. Ride and handling is much better than the Firestone M/T.
lmendham
Pennsylvania
Thank you very much! Jeep looks great
