Willys Edition JL Club Thread
steelerpsugirl
Maryland
2018 Wrangler Unlimited JL Sport S
Beautiful! So, what is the actual diameter of the tires you went with? Do you see/feel much of a difference from the stock 32" Firestones?
285 70/R17, it's a true 33". Main difference is that since they are an A/T they are quieter and have the 3 peak snow rating so should handle certain elements exceptionally well (obviously especially deeper snow!). I also like the wider stance and that it fills the wheel well a little more so the look is beefier. They are E rated but I don't notice any difference in that at all.
captainmac44
Morgan
Indiana
2021 Willys Sport
So, just an easy swap... no spacers or anything? I’d definitely go as big as I could on the stock rim, but I’ll have to wait until the Firestones are worn out... I wouldn’t be able to bring myself to spend a thousand bucks on tires on a brand new vehicle. Definitely looks good though!
steelerpsugirl
Maryland
Yup easy swap! If you go any bigger I'd get fender flares to be safe. I am currently trying to sell my Firestones to get some money back- hoping that happens! Usually I would wait a while but I got excited lol!
Hotplate51
Paul
Denver, NC
Jeep Wrangler JL Willys
I havent done any mods yet but one of the first ones I want to do is get the stubby antenna. Do you still get siriusxm? And is the reception still decent?
The SiriusXM antenna is on the roll bar right behind the passenger's head (#2 on the attached picture). I put a 6 inch stubby antenna on because it has no effect on satellite radio and I never listen to AM/FM.
Jeep Wrangler JL Willys Edition JL Club Thread s-l1600
WhitneyWillys
Sam
JLU Willys
Anyone with the Willys trim do the Rubicon suspension sway? What exactly would that entail? Since the Willys comes with Rubi shocks, I presume just four springs? Are the Willys LCA the same as the ones the Rubi comes with? Thanks.
EugenesAJeep
Palm Springs
2020 Willys
Just got that size also, General Grabber ATX- definitely the perfect size and look I’m after! I do love the Firestone MTs, interested in how different the two will be (ATX is a hybrid). Looks great!
Soooo, I did however have to take it to the dealer to have em” reprogram” for the new tires and wheels. The shifting points changed just enough that I wanted it right. about an hour and maybe $ $150 , I can’t remember, it shifts just right. Well worth the money.
steelerpsugirl
Maryland
Interesting... did you notice a difference? How did you know you needed to do it? I've never had to do that but I can check it out when I get my first early oil change!
EugenesAJeep
Palm Springs
2020 Willys
Yes, I noticed a difference, especially with the higher gears uphill at freeway speeds. Just shifted a little late. Could have easily lived with it.... if I had to.
Just to be clear. 3.6 automatic 2020 2 dr.
steelerpsugirl
Maryland
Good info! I have the 2.0L Turbo, but will definitely ask the dealer about it next time I go. Is there a specific name for what they did?
steelerpsugirl
Maryland
Should mention I have a tazer from my last Jeep so wondering if I can take care of it myself...
dmc3csc
Fremont, NE
2020 Wrangler Unlimited Willys
Shocks are the same, arms are the same. Springs are an easy swap. I gained about 1 inch over the Willys springs. I did also change the LCAs to the longer ones that come with the Mopar lift. There are several threads on here about the swap.
garyji
Gary
Western NC
2017 JK Sahara, 2021 JLU Willys
Huh??? Do diesel's have fuel doors?? I didn't know.
G.
