Willys Edition JL Club Thread
Turbo1974
K&R
Washington
2013 Wrangler
Thanks. Install is real easy. One wire for each light. Not sure a tech would even notice unless working on the headlight harness. Took me about and hour. Probably could do it in 30 if I did it again.
Can the Tazer JL Mini enable these corner lights as DRL's without adding a "hot" wire?
Tazer JL Mini – Z Automotive
Mudawg10
Chicago
2019 Wrangler
I’m not sure to be honest. I believe it can if you don’t care to keep them the same color. I wanted them to be led white for drls and amber for turn since that’s the legal way where I live. My understanding is if you use switchbacks the tazer won’t work for both colors.
zouch
Berkeley, CA
XJ, JLUWD
nice touch!
they're not stock. i bought my own and put them on before i left the dealers lot.
My dealer had Mopar locks installed when I picked it up. Yes, one on each wheel. All 5.
G
WillysGuy
Nate
KC Mo
Wrangler Willys Sport
welcome!
looks a lot like mine started out.
which motor did you get?
Thank you! I got the 2.0L. So far I'm digging it, but I haven't had the opportunity to go offroad yet. I live in the KC MO area and there aren't a lot of places to go locally, that I know of. As soon as it warms up a bit I'm thinking a roadtrip to Colorado or maybe Arkansas. Gotta start earning badges lol
Jvincent113
Jon
Buffalo
Wrangler Willys 2021
I have front and rear on my 2020 two door and on my 2021 4 door. Front fit fine. Rear does not fit exactly but good enough. Weather tech is close by so they took pictures and are hopefully redesigning them.
For the front, easy install. Don’t bother trying to “push out” the pin. Just drill it and save time.
As for the rear, the clips have a tendency to snap and break, making them useless and the screw could fall out. They don’t seem to line up. TIP: Use a large flare blade screwdriver to hold the clip from opening and thus snapping. Hold by placing blade right at the bend while using the short Phillips screwdriver to tighten the screw. You do not need to muscle and over tighten. Even with the non perfect fit I like them. They keep from getting rock chips and slush buildup.
Thanks for the tip! I was able to get the front mudflap's on yesterday without too much trouble aside from one of the clips just not wanting to stay in place. Will be working on the rear mudflap's today.
sk00pie
Paul
Long Island, NY
18 Sport S
Finally joined the group after 50 days from ordering.
Love this so much. Want either this exact setup or Sting Gray. Sky one touch right? Can you send more photos, possible outdoors in the sun?
WhereRU_A-A-Ron
Aaron
Arkansas
2021 Unlimited Willys, 2015 Toyota Sienna XLE
Restaurant Manager
Here is Sting Gray in the sun. Hopefully it’ll help you make a decision.
drshaws
2021 JLU Willys 6MT, 2015 Ody
All these pics of the new Willys are getting me even more pumped for my Hydro Blue build!! Should be here in 7 weeks.
Hydro was on my list, but didn't want to wait so we could get some use in this winter. I also really wanted the tan soft top, and wasn't sure how Hydro would go with it.
You should be pumped!
Clayton Offroad
