Will the plug-in hybrid Wrangler have a different dash instrument cluster?
pantheman75
Ryan
Washington
2022 Cherokee Limited, 2023 Wrangler Rubicon 4xe
I recently noticed that another FCA plug-in hybrid model (Pacifica Hybrid) has a different dash instrument cluster when compared to the standard engine equivalent model. Will that likely be the case with the new Wrangler Hybrid?
Standard Pacifica dash:
Pacifica Plug-In Hybrid dash:
roaniecowpony
Retired Engineer
Hybrids all have lots of instruments to tell you all kinds of stuff "extreme milers" might be interested in. So, if they didnt have a different instrument package, I'd be amazed and prospective customers would be disappointed.
RubiTuesday
JLUR
This image comes with the usual “pre production may vary...” disclaimers, but you can clearly see a tachometer on the left of the dash. If this holds, I wonder if it may speak to some differences between the implementation of the hybrid system and drive modes in PacHy vs 4xe.
Jeep Wrangler JL Will the plug-in hybrid Wrangler have a different dash instrument cluster? 4D32233F-DADD-4C03-9BC3-3A0544F2D201
Jehovasfitness
Maryland
JLUR and '04 Z06
It's hard to see but anyone with a PHEV, are you able to tell how many miles were driven in EV mode vs ICE?
Seems important for resale value or at least oil changes.
Let's say I drive to work 90% of the time and that's all on EV, that's not many miles on the ICE at all. Curious if there's a way to tell with the gauge cluster
Maller
CT
2019 JLU Mojito!
Found this in an article the other day.
Jeep Wrangler JL Will the plug-in hybrid Wrangler have a different dash instrument cluster? 1599786280899
KSpider
Noah
Escondido, CA
Audi E-tron (x2) ’21, Rubicon 4xe Nacho (on order)
honestly, that is such a terrible waste of space. You do not need thatch space for charge, especially on a PHEV. All that does is create range anxiety for people that are going to stare at it, it doesn't need to be any larger than a normal fuel gauge... that should be a speedometer.
RubiTuesday
JLUR
And in the photo I posted above, that’s exactly what it is. Tach on the left, speedometer on the right. I hope that’s the version that makes it to production.
BTW, that other gauge isn’t a charge gauge as in “amount of charge remaining.” It’s a gauge that shows how much power you’re pulling from or putting into the battery. A horizontal needle represents “no” current flow. The needle swings upward as the battery supplies more and more power to the electric motor. The needle swings downward under regenerative braking. The harder you brake, the more it swings down. That’s why from 3 o’clock downward it says “charge” because it’s charging the battery. From 3 o’clock upward is labeled “Pwr %.”
KSpider
Noah
Escondido, CA
Ah yes I see that, still should be smaller and better placed. But yes at least it isn’t battery / range.
JandS
Midwest
4xe | Exige S | R wagon | V Wagon | MB S65
4XE brochure shows a cluster that is a mashup of the Wrangler and Pacifica clusters.
