Will Sahara fender flares fit on a Rubicon?
tanyet
MS
GC
I know this is sacrilege but I like the lower look of the Sahara flares even with bigger tires. I know the higher flares will work on all models but I wasn't sure about the Sahara flares. EDIT: fit in title.
American Jeeper
Jeremy
Kansas
2019 JLUR
Software & cloud services
They will fit stock but the concern would be the bigger tires, and not sure how easy it would be to trim the ends. 35’s or smaller I would imagine you’ll be fine.
Sean L
Sean
North Carolina
You might want to check out the MOAB edition. Its got the beefy tires with Sahara fenders.
That is unless you're going for all the Rubicon hardware.
MYAMIA
MyA
MIAMI
Sahara JL 2018
It is a sacrilege yes, Lol. In my case having a Sahara would like to have the Rubicon fenders. Though, according to the pictures I saw, in Europe all Jls comes with the lower fenders, including the Rubicon.
Sean L
Sean
North Carolina
I think the Euro Rubicon has a smaller KO2 tire as well.
47Jeepster
Tom
Queen Creek, Arizona
2023 JLUR Diesel ... 2018 GC Summit
You could check that the part numbers for the body panels, that the flares attach to, are the same between the Rubicon and the Sahara. If they match, then the flares will fit. However, if they don't match that doesn't prove that they won't fit, it just means that you're back to wondering if they might fit.
PS ... look along the top right hand side of this thread ... just a little lower than the title line. Because you are the OP, you'll find a "Thread Tools" and the normally seen "Watch Thread" button. Click on the "Thread Tools" button and then the "Edit Title" button to change the thread title.
tanyet
MS
GC
Thanks 47Jeepster. I had assumed the board locked title edits.
Thanks for the replies everyone. I appreciate the information. I basically want a Sahara with factory lockers but since that isn't available I figured I might go with the Rubicon and trade flares with someone. That should be a good deal for someone wanting larger ones. I just 100% sure they would fit even though I know the Euro models have them. Most information I've seen says the Sahara should be able to handle the 33s too.
Sean L
Sean
North Carolina
I think once you see a Rubicon in person (if you haven't already) you'll notice they don't quite look the same as the Jeep.com renderings. For some reason the build and price fenders look a lot higher than they do in person.
tanyet
MS
GC
Good to know. I'm heading to a dealer this afternoon.
Sean L
Sean
North Carolina
And if you still don't like it, then I'm pretty sure it won't be a big deal to swap out with Sahara Fenders. The only issue I can think of is wether or not the paint continues past the fender and down the body. I'm pretty sure anyone that's swapped out their fenders will be able to answer that.
