Will Rubicon front bumper skid fit plastic bumper?
Sean L
Sean
North Carolina
Has anyone fit the Rubicon skid plate for metal front bumper to a plastic one?
I doubt the bolt holes would line up properly.
Sean L
Sean
North Carolina
Looking for someone that has tried it.
I’m going to dealership parts today to see.
I can compare the two tonight when I get home, I still have my old bumper at the house.
itstotalbacon
NE Pa
2018 Jeep JLU Sport S
From what I could gather you'll need the following parts
Skid plate - Mopar 68293984AB
P side bracket - Mopar 68353836AA
D side bracket - Mopar 68353837AA
4 x nutserts - Mopar 06511076AA
4 x bolts for brackets - Mopar 6104414AA
2 x bolt for skid plate into brackets - Mopar 06512587AA
Sean L
Sean
North Carolina
the steel plate uses different brackets than the plastic one.
Sean L
Sean
North Carolina
These are the brackets for the steel bumper
Something I was replying to got edited before I actually clicked on reply... :giggle:
Disregard my previous post.
itstotalbacon
NE Pa
Oh I did remove a part in my after I looked at it a little closer. Sorry about that :blush:
Rubidozer
Rubidozer
North Carolina/West-Central
2020 JLUR, 2018 Jeep JLUS
Yeah, you’re on the same page I was on....
I picked up the skid, brackets, etcetera. I discovered that the holes in the metal support, within the plastic bumper cover, do not match the mounting holes of the skidplate. I was planning on drilling new holes. The parts were approximately $125 but I’m not going to drill that support because it would deform under pressure on the skidplate.
It’s easier to just rotate the swaybar disconnect motor up and reattach using an open hole from the casting process. Just need to tap threads into it and use a longer bolt. It worked well on my JK with no problems. That way I can cut off the two supports for the plastic/steel skidplate/fairing just like on my JK.
So, yes, the skidplate can be used but it takes some holes that will weaken the actual front bumper cross support.
Rubidozer
Rubidozer
I’m going to make a bumper. First thought is to create it with a lower skid incorporated to have less steel but hug the frame rails. Sort of boxing in the frame, like I’ve done on the rears of my jeeps in the past.
That’s why I dumped my Gladiator and got a 2020 JLUR. I plan on using it as a rolling showroom eventually.
