YesHow do you guys turn off the annoying low tire pressure alert? Tazer?
The Tazer can be used to either shut the system off completely, or leave it on with a lower alert threshold. It adjusts down to 25psi.How do you guys turn off the annoying low tire pressure alert? Tazer?
Wife doesn't like the slight wander on a 2021 JLU Rubicon. I have no experience with a steering stabilizer. Will I notice a major change in vehicle tracking? Recommended manufacture's?
Anyone have a coupon code for allmoparparts? That $45 shipping is pretty steep
I just picked up my 21 JLUR last night and it was extremely windy on the way home. I was surprised at how much I had to be correcting my steering. Going to give the Mopar LCA's a shot!
Hi Darlene,We're sorry to hear about these steering concerns in your 2021 Jeep Wranglers. We would like to ensure that this information is passed on to the appropriate teams. Please send our team a private message with your VIN and mileage.
Darlene
Jeep Cares
The real battle is getting them loosened, rather than tightened.Received the LCA's today. What is the correct torque spec? I don't want to mess this up.
Is that a 4 or 6 foot extension on my torque wrench?190 Ft lbs........so a lot of grunts!
Did this work for you? Same issue and more noticeable wandering going down a mountain curvy freeway. Constant both hand gripping the wheel to constantly correct. Actually frightening me as the drop off was at least 1000ā on the other side of the guard rail.Anyone have a coupon code for allmoparparts? That $45 shipping is pretty steep
That's exactly the advise i was looking for. I have a stock 2018 JLUR with the exception of wheels and 35" trail grapplers. I have the new AB Box, track bar & damper (just replaced couple of weeks ago). Still have some wandering at highway speeds, but otherwise the new damper has helped when hitting pot holes and other irregularities that would unsettle it pretty bad with the original damper. I want to get the steering figured out before i do a lift. Debating on adjustable lower control arms since i do plan to lift at some point. I'm guessing most of the adjustable lca's would still work from a length stand point on a stock rubicon? Meaning when they are set to the shortest distance that wouldn't be a fitment issue? I probably won't go any more that 2" or 2 1/2".I had the exact same issues. Even with the cast iron steering box it didn't steer correctly. I called it flighty(ish) on the highway. I made two changes that transformed my Jeep. [I was just marveling at the steering while out this morning]
https://www.jlwranglerforums.com/forum/threads/big-driving-improvement-after-lca-swap.54439/
- Replace your lower front control arms with the Mopar fixed-length ones ($60 for the pair), that are .25" longer than stock, to correct your caster. If you plan to lift the jeep, you'll need slightly longer adjustable control arms ($200-$300) to compensate further for the lift.
- I was having a delay in my steering wheel recentering after adding a lift. I added a TeraFlex Falcon pass-through steering stablizer and the recentering problem was INSTANTLY fixed.
But...I'd only do the LCAs to begin. I was given this sage advice here on this forum and it worked like a charm. It was almost a abracadabra presto moment when I first tested it post-fix. You'll feel the difference in the first quarter mile. It's not a subtle change; it's transformative.
Yes, you can set the adjustable LCAs to 24.0ā (OEM length). Iād start by downloading a free angle finder app and measuring your caster. Youāll find directions on this forum. Itās a 60 second job. The sweet spot is to get your caster to 6-7 degrees (mine is 6.5)That's exactly the advise i was looking for. I have a stock 2018 JLUR with the exception of wheels and 35" trail grapplers. I have the new AB Box, track bar & damper (just replaced couple of weeks ago). Still have some wandering at highway speeds, but otherwise the new damper has helped when hitting pot holes and other irregularities that would unsettle it pretty bad with the original damper. I want to get the steering figured out before i do a lift. Debating on adjustable lower control arms since i do plan to lift at some point. I'm guessing most of the adjustable lca's would still work from a length stand point on a stock rubicon? Meaning when they are set to the shortest distance that wouldn't be a fitment issue? I probably won't go any more that 2" or 2 1/2".
Thanks for the response. I will do that.Yes, you can set the adjustable LCAs to 24.0ā (OEM length). Iād start by downloading a free angle finder app and measuring your caster. Youāll find directions on this forum. Itās a 60 second job. The sweet spot is to get your caster to 6-7 degrees (mine is 6.5)
One more thing. In terms of LCA length, a little goes a long way.That's exactly the advise i was looking for. I have a stock 2018 JLUR with the exception of wheels and 35" trail grapplers. I have the new AB Box, track bar & damper (just replaced couple of weeks ago). Still have some wandering at highway speeds, but otherwise the new damper has helped when hitting pot holes and other irregularities that would unsettle it pretty bad with the original damper. I want to get the steering figured out before i do a lift. Debating on adjustable lower control arms since i do plan to lift at some point. I'm guessing most of the adjustable lca's would still work from a length stand point on a stock rubicon? Meaning when they are set to the shortest distance that wouldn't be a fitment issue? I probably won't go any more that 2" or 2 1/2".
