Will any damage be done to the transmission if I don’t regear?
Jaon
Jason
Tennessee
Wrangler JLU
Will any damage be done to the transmission if I don’t regear? I have a 2020 sport on 35’s and never see 8th gear. I would like to just change out our axles for rubicon axles instead of putting money into a Dana 30. The hard part is convincing the wife.
word302
Oregon
JLU
Nah the transmission will be fine. Wouldn’t be worth it unless you were going to jump to at least 4.56. Most people say 4.88 is ideal for 35s. I’m running 5.13 with 37s and the manual transmission and it is awesome.
Yondu_JLU
Suwanee, GA
2020 Jeep Wrangler Sport S
I'm on stock gears with my 35" Nittos....personally I think they're fine for road use. I would HIGHLY recommend flashing your Jeep with a Tazer or an equivalent, though.
The only damage I've experienced is to my wallet at the gas pump....mpg is non-existent with the set-up 🤣
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
I am running 35 KO2’s with stock gears along with a steel bumper and winch and I don’t see 8th gear that often and it seems fine other than mpg loss, I did calibrate for larger tires.
JeepAustinWeird
Austin, Texas
2018 JLU Rubicon
I have 35's and running stock gears (4.10) and things seem fine. However I usually don't seem to notice what gear I'm in. I guess if you plan to do extensive off-roading, then could be more justifiable.
JeepAustinWeird
Austin, Texas
2018 JLU Rubicon
With the tazer, what exactly are you re-programming? (I don't have much knowledge regarding what all the tazer does).
Yondu_JLU
Suwanee, GA
It essentially allows you to set new parameters as opposed to the factory ones. So if your Jeep comes with 32 inch tires, and you're driving on a 35, 37, etc. without changing the computer's parameters, it'll shift as if you are driving on 32s. The Tazer allows you to change the size to your current tire size and thus the shift points will be more appropriate to your Jeep's set-up.
It also does a wide array of other things but that is what myself and many others mainly use it for.
JeepAustinWeird
Austin, Texas
2018 JLU Rubicon
[/QUOTE
Thanks for that info. The dealer did my recalibration after putting the 35" on when I bought it....guess that's what they used.
word302
Oregon
JLU
The only people who ever say this are those who have never driven a properly geared vehicle.
SouthernJL
Isom
Georgia
2007 Camry and 2014
Haven't received my JL but waiting on delivery, should be here any day now. However on my JKU Sahara, I regeared from 3.21s to 4.56 for my 35s and it was more than enough. Almost wish I had only done 4.10s. This is for the auto.
Of those that say 4.88s are needed for 35s, they must have a very heavy Jeep or live at high altitude, or both.
I've never felt underpowered with 4.56s.
Yondu_JLU
Suwanee, GA
Or they've just grown used to it and it doesn't bother them...?
word302
Oregon
JLU
you can't really compare the JL to the JK, completely different transmissions.
