Will a 1.5" spacer lift on XR need anything else?
Apexcars
North Texas
2020 RAM 1500
I already have the Mopar LCAs from their lift kit. Do you think that I will see any bad effects from adding 1.5" spacers with shock extensions up front and .75" rear spacers. Do you think this would badly effect the handling and if so what else do you think I would need to do to keep it as close to stock as possible. I still have plastic bumpers.
Carlton
Chicago
Jeeps lots of jeeps
You should be fine. I'd add an adjustable track bar up front to center the axle. If you want a great ride quality add some geometry correction brackets along with the longer arms. Get the caster around 7°.
