Thanks,looks great!
Many thanks for this - starting to consider the same size wheel/tire combo on stock suspension (for now) and really appreciate the multiple before and after angles!Here are before afters from the stock 245/75/x17 on 17x7.5 stock wheels.
Hope this helps...
You're welcome...Many thanks for this - starting to consider the same size wheel/tire combo on stock suspension (for now) and really appreciate the multiple before and after angles!
any issue with spare fitting on back? does it make the spare carrier not sturdy or weight down the back of jeep at all?I put 33" 285/70/17 BFG KO2s on my Stock JL Sport.
Wheels are 17x8.5" Fuel Anza -6mm offset.
No rubbing or issues at all.
Hope this helps
I have not had any problem at all with the 33 on the back. In fact my previous Jeep, a 2018 JL Rubicon had much larger 35x12.5s and it was no problem.any issue with spare fitting on back? does it make the spare carrier not sturdy or weight down the back of jeep at all?
You can fit up to 33.8” before rub (285/75r17)I have a stock 2dr JL. Will 33” tires fit? It’s 6speed 3.45 gear ratio
