Will 305-70-17 Sport S stock rims 2.5 inch lift Rub?
Swanny297
NELA
2018 JL
like that look alot Swanny - are they slightly more narrow than most seem to be running? I had some skinnies on my JK for awhile and loved them.
Yeah they are I wanted to make sure I wasn’t going to rub as when I lifted mine it was still early in the game and not a lot of info. I will be upgrading soon to 37s
corrh
peter
new york
2018 wrangler sport
I was thinking of those with a 2 inch mopar lift - you think they are wide enough with that lift? Looking for height primarily, not width. I have wider tires on my 2008 JK and while they look great, made it more sluggish than my pizza cutters. This new one will replace my JK as a DD with about 1% of my available time on mild trails/dirt roads. mostly NY snow on back roads is my "off road"
Mark7411
Delaware
JL Sport
Having a hard time with this. Can I fit these tires on JL Sport with factory rims without wheel spacer. I do plan on get 2.5 spacer lift. I’m hearing yes and no. Wasn’t sure if that size tire would clear.
See below
315/70/17
Nitto 217530 Details
17'' Wheel Diameter
Tread Depth: 16.4/32''
Tire Overall Diameter: 34.41''
Tire Section Width: 12.72''
Wheel Diameter: 17''
Spec Wheel Width: 8.0"-(9.5")-11.0"
Max Load @ Max Press: 2910 lbs @ 65 psi
Load & Speed Rating Index: 118Q
Mark7411
Delaware
JL Sport
Just did that set up, but with 315s. I’ll get a little bit of a rub with a full turn. I adjusted the steering stops and it helped. No Wheel spacers. You should be good with 305. I had a hard time find out the same question.
GrayWolf.Overland
Subash
Port Moody, BC, Canada
www.instagram.com
2024 4xe Rubicon (Earl Gray)
On stock rims wouldn't anything 295 out above rub at full turn on the control arms?? I thought that was the general consensus from previous threads.. it's baffling how you folks run 315s without spacers on stock rim and still no rub at full lock?? 😮😮
