Will 285/70 R17 will fit on a 17” x 10” -12 offset rim with no rub?
FastFraser
Orangeville Ontario Canada
2021 unlimited RubiconJeep
Hi all . Anyone know if 285/70 R17 will fit on a 17” x 10” -12 offset rim with no rub . It’s for a 2021 unlimited Rubicon with no lift . Thanks for your replies. Anyone running this setup?
blnewt
New Mexico
Just ask @cosine he knows!
That's the stock tire size, since you're going out rather than in you're good to go! If you have fender laws you may have issues w/ the tire poking out a bit from the fender though. Tire will be 3.5" further out from where it is now. This will also increase your scrub radius quite a bit which effects steering response.
https://www.wheel-size.com/calc/?wh...-17X10ET-12&fcl=2in&wcl=1.25in&scl=2in&sr=0in
