Will +18mm Offset on 35s fit non-lifted JL Rubicon?
amiii
Amir
Toronto
Jeep JL Rubicon
Hey Guys
Just wondering if this wheel/tire combo will work with a non-lifted 2019 JL Rubicon.
BFGoodrich ALL-TERRAIN T/A KO2 - SIZE: 35X12.5R18LT
On the following wheel (specs)
* Wheel Diameter: 18 in.
* Wheel Width: 8.5 in.
* Bolt Pattern: 5 x 127
* Offset: +18 mm
* Center Bore: 71.5
My main concern is +18mm offset. I don't really have much knowledge about offset just want to make sure this will work for a year before I get a lift and start some easy trails. (Not a hardcore offroader)
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
that equals a 5.46" backspacing which is a lot. it might work on the street but i think it would rub the inner fenders like crazy if you take it off road and flex at all.
77RRAD
Ron
Las Vegas
2019 JLUR
I am on 37s but 2 inch lift with +25. Barley rubbed at the back tire to the bottom plastic piece but was able to heat it up and get enough clearance.
amiii
Amir
Toronto
Jeep JL Rubicon
So basically a 18 x 8.5 wheel with +18 mm ( 5.46" backspacing) would rub on the suspension without spacers? I want to stay away from spacers if possible. And for now I'm not planning to do any off-roading maybe some easy trail at most. The wheels will be going on a 35x12.5R18LT? I really like the wheel, it does come in a 17x9 but the particular pattern on the wheel just looks too small on 35's in my opinion so I was hoping I can get the 18x8.5.
Bryce
Bryce
Acworth, GA
2019 JLUR
Stock JL Rubicon wheels are 17x7.5 with a +44 offset. Are wun 285/75R17 tires without rubbing.
AEV JL specific wheels are 17x8.5 with +25 backspacing and are supposed to be fine with 315/70R17 (metrics 35s). They better be, my set of AEV Borahs show up today.
Your 18x8.5 +18 wheels will pus the center line of the wheel 26mm outwards or approx 1 inch. Your going with a tire about 1.3 inches wider, but half of the width on each side, so the inside of the tire will be approximately .35 inches further away than stock.
I found this on the customoffsets.com website
Jeep Wrangler JL Will +18mm Offset on 35s fit non-lifted JL Rubicon? 20200526_070853
amiii
Amir
Toronto
Jeep JL Rubicon
Thanks, so in that case I should be fine and there will be no rubbing correct?. Please let us know how your AEVs are and post pictures if you can.
Bryce
Bryce
Acworth, GA
2019 JLUR
I can't say fir sure that they won't rub, but U suspect they will be OK.
For now, I'm going to swap the 285/70s to the Borahs. I want yo use them up and build the Jeep funds back up for new tires.
Goblue
Darran
JLU/OB
FF/PM
Yep copy that Im in the same boat...could not pass up on that deal...not sure if they've ever done such a thing
amiii
Amir
Toronto
Jeep JL Rubicon
Just realized the same wheel I was looking for comes in the following specs.
  • Wheel Diameter: 18 in.
  • Wheel Width: 8.5 in.
  • Bolt Pattern: 5 x 127
  • Offset: 0 mm
  • Center Bore: 71.5
0mm is like 4.5 backspacing correct? This should be safer option compared to the +18mm offset?
