entropy
- Sep 19, 2018
- Foothills of the San Gabriels
- Jeep Wrangler Sport S JL 2-D
- Build Thread
- Link
- Occupation
- Professional dancer/male stripper
so did you install them already?. So the links are connected to the sway bar at the top and to the frame at the bottom. You disconnect at the frame connection. Then you move the sway bar up to secure the links.I am trying to find a video on How to USE them. There are a thousand videos on how to INSTALL them, but not one on they are used...!
Do you release the bottom or the top of the link? What is that pin sticking out next to the fender liner for? Do you need to release both sides?
You cant release the top. that would require tools, so whats the point of that?. The idea here is that there is a safety pin holding them in place at the bottom. You remove that pin and disconnect the link. them you rotate the link out of the way, rotate the sway bar up which should be free to move now, and secure the links on that pin youre talking about. That pin is just so that you can secure them in place, out of the way of your tires, so you dont blow a tire hitting the link.
This should become very obvious after you install them.
