AgreeWhy is the rear limited slip differential not standard equipment on a Wrangler Sport or Sahara ?
It’s a “Trail Rated” Jeep Wrangler, not a Jeep Compass
Why isn’t every option “standard” equipment? Is this a serious question?Why is the rear limited slip differential not standard equipment on a Wrangler Sport or Sahara ?
Why do you conflate limited slip with trail rated?Why is the rear limited slip differential not standard equipment on a Wrangler Sport or Sahara ?
I’ve been over terrain with an open differential in my TJ that most here likely wouldn’t dream of touching. You would have a hard time convincing me I need a limited slip to be considered “trail rated”.My thought is this... when I think trail rated, I think the ability to get over/go through moderate obstacles fairly easily (with good driving assumed). Therefore, I think of the wheels that get the best traction for what is offered and in most cases this starts with good tires and some form of limited slip or in more advanced cases lockers. I look at Jeeps, especially a trail rated one, for this to be inherent. Therefore the Jeeps that do not have one of these option, I feel may not deserve the trail rated badge unless they are modified in some form.
Was it stock?I’ve been over terrain with an open differential in my TJ that most here likely wouldn’t dream of touching. You would have a hard time convincing me I need a limited slip to be considered “trail rated”.
You’re missing the point. What percentage of wranglers do you think ever see a trail? Even the vast majority of Rubicons never leave the pavement. Why would FCA make something standard equipment that the majority of its buyers have no need for? To answer your question, I had a 2” budget lift and 31” tires. Eventually added a winch. Would have loved to play follow me with the majority of New wrangler purchasers.Was it stock?
I'm pretty sure the BLD works with the optional antispin as well. Guess i need to go get stuck just make sureWell the non-limited slip equipped wranglers come with BLD which works like a LSD but isn’t near as smooth. Also the LSD comes in a Dana 44 rear end...so yes...they make money on it, but for the price of the LSD, it’s quite a bargain!
My CJs and old Land Rover had open diffs. Took them all over the place offroading. Well at least when I lived in Colorado and the offroading opportunities were numerous. Now I live in flat Chicagoland. Anyway you don't need LSD, although I would order the LSD as mentioned to get the uprated rear axle if it's not a Rubicon model.Why is the rear limited slip differential not standard equipment on a Wrangler Sport or Sahara ?
^ Agreed.I’ve been over terrain with an open differential in my TJ that most here likely wouldn’t dream of touching. You would have a hard time convincing me I need a limited slip to be considered “trail rated”.
