Why is Auto Stop / Start inoperative once the "Low Fuel" light comes on?
tlmacson
Mac
Detroit, MI
2019 JLU Moab
I can't help but question the underlying justification for Auto Start / Stop as a fuel conservation tool when the programming overrides its use when your down to your last 1.5 gallons or so of fuel. Can someone please explain?
Gregodav
Wichita, KS
Rubicon 2014, Solstice 2007, 1993 GMC Pick-up
I. T. Director and Video Director
I can't help but question the underlying justification for Auto Start / Stop as a fuel conservation tool when the programming overrides its use when your down to your last 1.5 or so of fuel. Can someone please explain?
I think the engine is prohibited from starting when your tank is near empty to ensure you do not run out of gas.
tlmacson
tlmacson
Mac
Detroit, MI
2019 JLU Moab
But doesn't shutting down the engine conserve fuel?
Joeymon1
Southern Tier, NYS
2019 Sahara
I expect that was a bit of humor.- " won't start so you won't run out of gas"
I never noticed ESS not functioning when low fuel is showing. Will look out for it.
ChrispyJL
chris
Rockaway, NJ
2018 Punk"N JLU Sport s
Building Mechanic
An engine requires a bit more gas to turn over, as opposed to running at idle.
Will
Will
Georgia
'18 JLUR
I have noticed it. I was struggling with the same thought process one day and I finally settled on: “Maybe I should just go buy some gas”. Instead of watching the engine cut off and on 10X before I get to the pump.
There are situations where it saves some minimal fuel, some where it’s questionable, and some where it’s obvious that it’s not needed: for instance, mine cuts off when I pull into the garage, then cuts right back on when I shift into P, then I turn the thing off. Very annoying.
I doubt there were any Jeep engineers that wanted to put this system in the Wrangler. I’m convinced it was government requirements that ultimately got it under the hood.
mazeppa
y = x/0
ICBM complex at Kodlosk
2021 JTR Panda
knife sharpening snob
Ingenious, finally a simple inexpensive way to disable ESS. Just keep 1½ gallons or less of fuel in the tank at all times omitting the need for a device to connect to the vehicle’s CAN or the horror of actually having to push the button on startup EVERY TIME. :like:
Sean L
Sean
North Carolina
Approxamately 6 seconds of idling is equivalent to a cold start (warm start uses a little less) according to Engineering Explained on YouTube. Beyond those 6 seconds (Like sitting at a stop light for 2-3 minutes) ESS has benefits.
Sean L
Sean
North Carolina
So as far as the Original post, I haven't noticed ESS failing to work when I'm low on fuel. It will still operate as normal, just as with a full tank.
TimmH
Timm
2018 JL Wrangler Sahara 3.6 Auto
Agree with Sean L, I've been on low fuel warning and has the ESS kick in. My Wife and I test drove a Cherokee Sunday that had 13 miles Range To Empty and ESS kicked in during the test drive.
biggprikk
Blue Bell, PA
2018 JL Rubicon
Jeep Thing
