Why do some Rubicons stand taller than others? (Stock, no lift)
RamMan
Frank
Oklahoma City
JLU Sport Dsl. / '16 Ram PW / '14 GC Dsl.
Transport / Odd Jobs
All the more reason to lift it and make the rest have to look up when you pull along side them. ;)
Taller tires are another "lift". Rubicons use taller tires which negates the 4.11 diffs.
GATORB8
CLT NC
21 JLUR 4xe
3.45 - > 4.10 is a lot bigger difference than the stock tire difference.
A stock rubicon with 37s would have the same effective ratio as a Sport 3.45 on stock tires.
A stock rubicon with 35s would have the same effective ratio as a Sport with optional 3.73 on stock tires.
viper88
Nick
IL
'19 JLR 2.0T
Steel Bumpers, towing package, steel bumpers with towing package, 392, 4xe or diesel (weight diff), hard top vs soft top vs SOT, amount of gear or occupants inside, factory tolerances, and combination of the previous... There are plenty of reasons to see differences. Even lighting and angle.
Yep. Even different colors, painted and non-painted fenders can make one look higher than another.
DadJokes
Daniel
Kentucky
Sahara
I feel like our ‘21 3.6 eTorque sits lower than any JLU Rubicon I’ve seen. It’s lower than what our 19 Sahara 2.0 eTorque was with the previous Rubicon suspension too. I verified the current spring part numbers are stock (bought with 3500 miles on it) but they are lower part numbers than the earlier years it seems. It has tow, hardtop, and steel bumpers. It’s fine for us though.
RamMan
Frank
Oklahoma City
You are correct Sir. Thank you for pin pointing this. I was thinking more in round numbers to my JLU Diesel Sport 3.73 diffs, additional weight of Rubicon over a Sport etc. The factory steel wheels/tires are the lightest of any. My Fuel 17s & 265 / 70s are quite a bit heavier than the factory's. This tire size is wider & a hair shorter (1 MPH) than standard. I getting a hair closer to the 4.10s
D&C Designs
