Who's got a fix/repair check list before the warranty runs out?
Chaostactics
Hawaii
JLU
Our JLU is a bit less than 200 miles from being out of warranty.
What are the essentials to get finished/done while she's under warranty?
We got the bubbling hinges replaced and we got the faulty clutch switch replaced.
DaltonGang
Houston, Tx
Make a list, take it in, and make sure you have them addresses everything on the list, before you pick it back up. Even the small issues need to be noted.
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
Have them run all of the codes on it (not just the engine). That way, there could be an intermittent problem that will turn into a permanent problem down the road. This could be anything from the blend doors in the HVAC system to door locks.
RedundanT
So. Il
2020 JLUR
Is there an issue with the Jeep? Or are you just wanting the dealer to fix something that "might" break in the next 20K miles?
Chaostactics
Hawaii
JLU
Yes pretty much. Anything that's known to break that I've not yet looked at.
