Dalma
- Dale
- Oct 8, 2019
- Vancouver Canada
- 2019 Jeep Rubicon - Bikini Pearl
Whos upper shelf are you using here?
My slide has 4 bolts. Three on the driver side that use the exsisting bolts and on the other i have one bolt in the rear through the tub. It is solid enough. Been on several trips and no problems.what does your slide bolt on to?
I have the Hooke that i bought from Ebay. It was cheap and has worked well. Only issue is that i needed to modify it for the fridge to fit under. Because of that i have been looking at another shelf that bolts to the rollcage.Whos upper shelf are you using here?
What slide is this? I have not seen this setup before looks great!The driver’s side. There is still enough room to store some Wolfpack storage boxes with the ARB 50.
With the Goose Gear Base plate can you put the rear seats back in? Non of the photos on their website show the base plates with the rear seats in.Domestic 45 on Dometic slide and Goose Gear base plate. Shelf if from Vector Offroad.
nice this will be my same set up when life allows me to have time to need it. I have some bumper too!Domestic 45 on Dometic slide and Goose Gear base plate. Shelf if from Vector Offroad.
My rear seats are installed and in the normal position in that photo.With the Goose Gear Base plate can you put the rear seats back in? Non of the photos on their website show the base plates with the rear seats in.
Sweet! How do you like it? Did you just screw your sliding drawer right into the Goose platform? I don't like that the access lock for the compartment sits proud. It would be better if it was flush.My rear seats are installed and in the normal position in that photo.
I love the Goose Gear setup! Definitely pricey but you get what you pay for here IMO. I asked Goose Gear for a few additional nutserts and drilled some additional holes for the Dometic fridge slide to mount it exactly where I wanted it.Sweet! How do you like it? Did you just screw your sliding drawer right into the Goose platform? I don't like that the access lock for the compartment sits proud. It would be better if it was flush.
