Who else manipulates ess with brake pressure?
track.n.trail
Owen
San Francisco
2020 JLUR
Software Engineer
I’ve turned ESS off permanently with a TazerJL. Pointless feature IMO
Sgt Beavis
Rick and Miyako
Wrangler JL Unlimited Sport S
The Man, The Myth, The Legend. In my own mind.
I used to use that trick to keep the engine going. Then I got the Tazer JL. Life is much easier now. ;)
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Turned off mine with a Smart Stop/Start module like 2+ years ago never have missed it.
Sean L
Sean
North Carolina
To everyone talking about permanent disabling of the Start/Stop... you're beating a dead horse, that's not what OP was asking about...
Jeep Wrangler JL Who else manipulates ess with brake pressure? tenor (11)
Strategic use of the Start/Stop is the purpose of the brake pressure method, not permanently disabling the system.
ErAcEr
Matthew (Mateo)
Indianapolis, IN
2018 JLU, 2021 ZH2 , 2018 Z900, 2013 Vulcan 1700
Engineer/Technician
I’ve been playing around with trying to have ess activate only when I want it to. It seems that one of the main triggers is additional brake pressure after stopping. Its fairly easy to keep it from activating by slowly releasing brake pressure as you stop, and then being careful not to add more pressure after you stop. Doing this has become routine and now I basically activate it only at long lights or other situations I know it might actually save a little gas. It’s not 100%, but works most of the time.
Just curious if anybody else does this.
Two questions to this since I have a MT
1. Does the AT have a trans-brake for when stopped on hills like the MT does?
If so
2. How does the pressure trick apply to hills (or what you have noticed), or do you have to go full stop?
Thanks
Sean L
Sean
North Carolina
If so
Thanks
ESS is disabled by the computer when you're on a steep enough of an incline. The AT still has a "Hill Start Assist" that I found to make the ESS restarts to be very jerky so I turned that off. It didn't make much sense to me for an AT anyways.
