White smoke on startup of 2.0L
Rploaded
Houston
2019 JLUR
No odor at all
Is the drain for your exhaust pointing down so it’s draining properly?
You could put a bucket over the tip and start it. See if you can collect the vapor, I’m guessing it’s just water vapor. Feel free to smell and or tongue test the results to be extra sure.
PJAMMR
PJAMMR
Michelle
Jl
  • Thread starter
  • Thread Starter
  • #18
Yeah okay. No need to act like a douche.
clemson
Rick
NC
2018 JEEP JL SAHARA UNLIMITED
Folks...all turbocharged engines are tuned in such a way that the engine must get hot faster than non turbo. What you are seeing is the hot exhaust coming in contact with cool surrounding air. As the engine heats the exhaust temp lowers as the thermostat opens
LeodaJeep
Leo
SoCal below Idyllwild mountains S.W. side.
2019 Jeep Wrangler JL Rubican
Self Sufficient
In cooler temps it is prob. normal. Keep an eye on your radiator reservoir though because if you have a blown/leaky head gasket your reservoir level will drop over time.
palumbum
Alex
Charlotte. NC
2016 Jeep Renegade Sport
Figured I'd contribute and say thhis happens constantly with my 2020 2.0 sport s unlimited. Was also told it's breaking in and it only last for 2 minutes or so. Morning are like 45 degrees
bautistasamuel
Samuel
NY
2018 JL Wrangler Sahara
It can happen because of-
  • internal coolant leak
  • transmission fluid
  • cracked cylinder head
  • fuel injector
  • broken fuel pumping injection
  • faulty piston
  • oil level
  • water contamination of fuel
If you want to know them in detail, check this blog about white smoke from exhaust.
palumbum
Alex
Charlotte. NC
It happened nearly every start up for me, but not once since the weather has warmed up. Seemed to only happen in either the winter or when it was under 5k miles.
LeodaJeep
Leo
Self Sufficient
It’s just condensate due to the atmospheric moisture and the differential in temperature between your engine and the outside temp.
Extreme Terrain
