ChaosFromTejas
Recently had delivered some amazing rock sliders from White Knuckle Off Road. These suckers are beefy, frame mounted sliders that can support the weight of my JLUR, as they should. I ordered the 45 degree version that is less of a step, but hugs the pinch seam and door panel really well and I just love how it looks. They also are shaped with a kick out at the rear end of them so any rock you’re stuck against gets directed under the tire rather than ripping off your fender.
Only issue I had is that they share a mounting point with my MetalCloak skid plates, where the original skid crossmember used to be. The bad news: only real way to have them share the bolt hole is to loosen the skid plate and remove that bolt, and mount the sliders between the plate and the frame. This creates a 3/16” gap between the plates and the frame, rather than cinched up tight to the body as before. Good news is: A 3/16” washer on the other frame bolts can even out any tension in the skid. Pictures can probably explain that better than words.
I’ll post pics as soon as I can, but I felt some people might like to know that these two items can be mounted together without any serious modifications required, so long as you don’t mind a tiny gap above the skid plate lip.
