Whistling/wind noise with top down
jpqst
Charlotte
Jeep Cherokee
This is not the infamous windshield noise. It is only when the top is all the way down and starts at 30 mph. No issues when up, in sun rider or safari. It sounds like its coming from high up and in the rear. Anyone else experience this or know how to stop it?
robaw
Rob
Iowa
Did you lock it down with the latches on the roll bar (flip to lock position and then push top down until it clicks)? Maybe try using Velcro traps to compress the top? I haven't used my soft top yet but those are a few things I've read about that might help.
jpqst
Charlotte
Jeep Cherokee
I did not but ill give those a try. Thanks
xeon
JLU Rubicon
I had my soft top on for a few months last summer and had it down frequently. What I can tell you is if you dont fold the top as instructed and make sure you push the material out between the spars in the direction needed..you can get some pretty wacky sounds. After I showed my oldest how to put the top down properly that has gone away. As others have discussed in this thread make sure your top is locked. To reduce flapping and I strap i strap the top with two 2" velcro straps and make sure its a pretty tight bundle.
Now I am sure you are familiar with all the sounds that a Jeep can make while the tops off / down. But even at the right speed and conditions the radio antenna will whistle. Whistles are typically caused by thin openings exposed to a deep hole. Some times the interior panels will get a gap and the wind within a convertible will just catch it right and cause a whistle. Had a BMW that did this...drove me nuts. I had to cover up seams with tape until I found the one that caused it then I filled the seam with calking and no more whistle but there are so many more possibilities in a JEEP that could cause a whistle, I rather just turn up the radio and go faster :) But I feel your pain and hope you find it.
jpqst
Charlotte
Jeep Cherokee
I appreciate the helpful responses. The JL I test drove didnt do this with the top down so I wil try these suggestion. Thanks.
uRJeremyK
Jeremy
Orlando, FL
my JK had a whistle with top down, was the round ring at base of side view mirror. wind just whips around it. haven't noticed it yet with my JL. I could put my hand around it and make it stop. drove me insane.
UKCATS
DFW
2020 JLUR Recon/2020 Mazda3 Hatchback
I play piano in a whorehouse
DaFuq?
allieboy
Bob
Phoenix
2019 Sahara
It stopped for me when i put an ear plug in one ear
jpqst
Charlotte
Jeep Cherokee
I appreciate all of the constructive comments. I folded the top carefully this time and used 2 bungee cords to hold it down and the whistling went away.
MedicalCowboy
Jonathan
North Alabama
2019 Jeep JLU
Pipefitter
Hey guys when I take my doors and top off I get a lot of wind noise and the sun shines directly on me. Does anyone know how to remedy this? :computerrage: Hahahhahahah
Northeastbst
Amaral
MA
Rubicon JL
"I took my convertable top off..now I hear wind noise and whistling,,, please help!!"
