Which tail lights do you have?
NINTH
NINTH
Jay
Socal
2 door JL Sport
They do, and magnet mount as opposed to Oracle with no mount.
edit - you would think you could order with or without, but nope, they all come with them.
Since it comes with resistors isn't it just plug and play without having to use Tazer or Jscan to configure LED settings?
Originally had halogens and the current Raxiom LED tail lights I have were just plug and play because it had resistors also
Mr. Nimbus
Jeep Wrangler 2025 JL Willys, Toyota Tacoma 2012 TRD Off Road
I thought the Morimoto comes with resistors for plug and play for halogen?
They do. You can use the resistors if you prefer when swapping out from halogens. I wanted to go with LED-appropriate power levels instead so used JScan to reprogram. Resistors generate a bit of heat, if you do use them.
NINTH
NINTH
Jay
Socal
2 door JL Sport
Ah got it, thanks
Framer
G.
2024 Wrangler Rubicon X 4xe
I've got the Oracle flush mount smoked. I also have the backup lights in place of the reflectors and in the tow hitch. Tons of backup lighting.
Since the BSM sensors do not work on the Oracles I'm going to be pulling them out. My wife hates that they go off when they shouldn't and vice versa.
Sounds like the Morimoto is the only flush mount option where the sensors work. Currently on sale for $368. Any other flush mount options where the BSM sensors actually work (besides OEM)? Will be listing the Oracles for sale. 6 months old and otherwise work great.
Jeep Wrangler JL Which tail lights do you have? IMG_9203
Bill_BCNtoNY
NY
Ocean Blue JLU Sahara 3.6
Advisor to Boutique Consulting Firms and Solo Practitioners
IIRC, there are shims available to adjust the sensors on the Oracles. Can anyone wiser please confirm?
Heimkehr
Pennsylvania
2021 JLU 2.0T
Shimming was recommended by the company when the poor functioning of the BSM modules first came to light via owner feedback. IIRC, the owner was to configure the shim solution himself.
Framer
G.
The factory LED tail lights have 2 issues that bother me: reverse not bright enough and they protrude too far from the vehicle and grab brush, tree branches and the like. Probably could live with both issues but I really liked the flush/clean look of the Oracles.
I couldn't figure out any way to shim the sensors. They are held firmly in place by the housing inside the tail light that was engineered especially for them. Makes me wonder why Oracle went through all that work fully knowing the position of the sensor was not correct on the JL. I've heard they do work on the gladiator but I can not confirm this.
When I take them off I'll post a couple pictures of the "inside" of the tail light and where/how the sensor is located.
