Robbyreneeward
Looking at amp and RSE. Opinions???
What steps did you chose?Looking at amp and RSE. Opinions???
Why that choice if you don’t mind me asking? Also how was installing?I had these put on my jeep, i like them so far.
https://www.ariesautomotive.com/all...rangler/328/ActionTrac+Powered+Running+Boards
The dealer had them installed at a local shop. I like the boards, although i have had problems with the led lights that light up when they deploy. The boards are stable and have ample room to step up on them to get in and out of the jeep.Why that choice if you don’t mind me asking? Also how was installing?
Look sweeet!! Any tips on the install?Just installed the slide engineering sliders with step today. They are not cheap but are very nice and are stout. Our jeep is our overland and rock crawling rig so we wanted a step but good protection.
I used heat on every body mount bolt to make sure I did not break one, which I guess sounds pretty common. I heated each one and worked it back and forth slowly. It appeared to me that both front body mount bolts had red locktite from the factory so i wonder if those are the ones people are breaking. I installed the entire wire harness loose and zip tied it all done very last. The install is pretty straight forward and not to difficult. The interior trim panels can be a little bit of a pain to pop loose. They push in towards the inside of the jeep not up. I keep reading people having issues with the steps. I guess time will tell but it sounds like their customer service is very good.Look sweeet!! Any tips on the install?
Awesome thanks !!I used heat on every body mount bolt to make sure I did not break one, which I guess sounds pretty common. I heated each one and worked it back and forth slowly. It appeared to me that both front body mount bolts had red locktite from the factory so i wonder if those are the ones people are breaking. I installed the entire wire harness loose and zip tied it all done very last. The install is pretty straight forward and not to difficult. The interior trim panels can be a little bit of a pain to pop loose. They push in towards the inside of the jeep not up. I keep reading people having issues with the steps. I guess time will tell but it sounds like their customer service is very good.
RSE boards expected to arrive tomorrow, thanks for the installation info!I used heat on every body mount bolt to make sure I did not break one, which I guess sounds pretty common. I heated each one and worked it back and forth slowly. It appeared to me that both front body mount bolts had red locktite from the factory so i wonder if those are the ones people are breaking. I installed the entire wire harness loose and zip tied it all done very last. The install is pretty straight forward and not to difficult. The interior trim panels can be a little bit of a pain to pop loose. They push in towards the inside of the jeep not up. I keep reading people having issues with the steps. I guess time will tell but it sounds like their customer service is very good.
