BillyHW
Okay, so I've read the internet trying to get the right answer to this question, but there appears to be a few answers that people give in roughly equal frequencies with roughly equal passion, and I don't know who is right.
Which of these statements is correct about recalibrating for larger tires (or higher axle or transfer case ratio) with an automatic transmission?
1. Automatic transmission shift schedules do *not* need to be adjusted, because they are based on engine RPM, not vehicle speed. When you are recalibrating you just need to make the speedometer read correctly so that you don't accidentally get a speeding ticket because you didn't know the true speed you were going.
2. Automatic transmission shift schedules *do* need to be adjusted, because they are based on engine RPM *and* vehicle speed, but the computer will automatically adjust these schedules once you recalibrate the speedometer so it is getting the true correct vehicle speed.
3. Automatic transmission shift schedules *do* need to be adjusted, because they are based on engine RPM *and* vehicle speed, and you need to reprogram these shift schedules in the computer yourself with some sort of calibrator tool that can do this in addition to just recalibrating the speedometer and odometer readings.
I'm hoping the right answer is #1 or #2, because that would make life simple. But if it's #3, does anyone know if the Tazer, ProCal, or Mopar Calibration Service reprogram the shift schedules correctly, or do they just recalibrate the speedometer and odometer so they read correctly? Which tool does the shift schedule reprogramming too?
