PriceForFlight
I have mine set at 40 amps on my 50 amp circuit. Works great.Do you have it set at 32 amps, which is what the Mopar charger is, or is it ok to have it set at 40 amps (on a 50 amp circuit). Thanks!
In your search did you ever run across one with a longer than 24' cable? I'd like to mount it on the back wall of the garage (about 22' deep) and be able to charge just outside the garage. Prob need just a few more feet for that. 28-30' would be perfect.I started with this charger:
https://www.amazon.com/gp/product/B07Z7N6QZX/
LEFANEV branded, I bought the model with an N5-60 plug, provides 32a out, and has a 20' cable. Not 100% sure on the warranty, assuming since it's not mentioned, it's probably just a year. $415 from Amazon (at my time of purchase, but in getting that link, I noticed they're sold out ...)
I did! PRIMECOM makes a charger that looks identical to the first one we had (so probably the same manufacturer upstream somewhere ...), 40a with a 30' charger cable:In your search did you ever run across one with a longer than 24' cable? I'd like to mount it on the back wall of the garage (about 22' deep) and be able to charge just outside the garage. Prob need just a few more feet for that. 28-30' would be perfect.
Thank you so much for taking the time to provide all the info! I'd rather have the single cable as well and yes, I completely believe they all come out of the same factory!I did! PRIMECOM makes a charger that looks identical to the first one we had (so probably the same manufacturer upstream somewhere ...), 40a with a 30' charger cable:
Got our Grizzl-E 40a Smart charger in and mounted. Per a previous post, we had a 50a circuit added to our box with an N6-50 receptacle right next to it (only $225 for the install).
Anyway, holy smokes, the Grizzl-E is a seriously stout product, all the fasteners are high grade, the case thickness, the insanely heavy duty cables. I went ahead and ordered direct and paid $40 more (vs. Amazon pricing) for a "smart" model - it's OCPP 1.6 compliant which allows 3rd party apps to manage/monitor over WiFi, I might code something custom to access the data on the box (the API) appears to be open source (NERD!)
It also has a metal charging connector lock, options for N6-50 or N14-50 plugs, a 3 year warranty (with an option for 5) designed in Canada for their weather, so water resistant, cold resistant (obv. up to a point). Ours is mounted in the garage, but we're 2 blocks from the ocean, and things tend to ++dissolve++ around here, so I'm glad it designed to withstand the elements.
Oh yeah, it also has a super nice - seems to be stainless - mounting bracket, it's two pieces with a locking pin, so the charger is easily removed from the wall without any tools.
Mine was preset for the max 40a (giving me the recommended 20% tolerance on a 50a circuit), and the 4xe only pulls the ~30amps it needs. It can be set via internal dip switches to a fix max, if, for example, you're running it on a 30a circuit (I think there's a 24a setting).
Which 3rd party app are you using with it?Got our Grizzl-E 40a Smart charger in and mounted. Per a previous post, we had a 50a circuit added to our box with an N6-50 receptacle right next to it (only $225 for the install).
Hi Masked, I followed your advice and ordered the Grizzl-E 40a Smart charger. Can’t wait for it to arrive so I can have it installed. Thanks for sharing your experience!
None as of yet, I kind of just sprung for the smart version since it was only $40 more, figured, it was a little future-proofing.Which 3rd party app are you using with it?
i also have the Smart version and have it connected to the acharger.ca portal. Mine hasn't been trouble free. Works successfully for 3-5 recharges then next time around it won't intitate charge sequence for 20+ plugging attempts. Then it will somehow suddenly work or errors in solid red light. Unplugging it from outlet usually fixes the issue but that's not a solution I want to deal with long term.Excellent. I think you'll be impressed with the build quality, the case, cables, fasteners, bradckets, just really well engineered. They're even in your neck of the woods (HQ'ed in Toronto).
The other terrific thing is having a direct line to the original manufacturer, like when I called about my order, and an actual person answered the phone and my question in like 2 minutes.
I did see that United Chargers who make the Grizzl-e products has a free service, but I didn't connected our charger to it, only to the local WiFi. I setup an account on that service, it looks OK, I may wind up connecting to it to see it work, and maybe monitor some network traffic to see what's being exchanged (I'm a touch leary about a rando box/service that has access to local network data ...)
I'm going to start looking into the API, learn more about how things are implemented. It appears to me as of writing this, that the charger itself, is in charge (*snicker*) of negotiating the communication, i.e., you don't "connect" to the charger with a client app, the charger side connects to a service, so it must push data out or once connected, provide an access token (so the service could poll it).
I was getting occasional unrecoverable errors on my non-smart Grizzl-e. The plug is wired through an old school switch, so turning the switch off then on reset the charger. Then one day it was totally dead. Turned out the old school switch had old school screw-in glass fuses in the box and one was loose. Kind of ironic that all the fuses in my Jeep were fully seated on delivery, but I end up with a non-seated fuse in my charger set-up. Tightened it up and all was good. No errors since then.i also have the Smart version and have it connected to the acharger.ca portal. Mine hasn't been trouble free. Works successfully for 3-5 recharges then next time around it won't intitate charge sequence for 20+ plugging attempts. Then it will somehow suddenly work or errors in solid red light. Unplugging it from outlet usually fixes the issue but that's not a solution I want to deal with long term.
Having the same issue. Seems to be when I go for more than 24 hours between plug-ins, but that's just a guess at this point. Unplugging the charger from the wall for 10 secs and plugging it back in seems to fix it. On two occasions I only unplugged and replugged fairly quickly and that didn't work - only leaving it unplugged for 10 secs or more seems to work - so the fix requires a complete internal discharge.i also have the Smart version and have it connected to the acharger.ca portal. Mine hasn't been trouble free. Works successfully for 3-5 recharges then next time around it won't intitate charge sequence for 20+ plugging attempts. Then it will somehow suddenly work or errors in solid red light. Unplugging it from outlet usually fixes the issue but that's not a solution I want to deal with long term.
What firmware version? My Grizz is on 05.32 which appears to be latest available for download.Having the same issue. Seems to be when I go for more than 24 hours between plug-ins, but that's just a guess at this point. Unplugging the charger from the wall for 10 secs and plugging it back in seems to fix it. On two occasions I only unplugged and replugged fairly quickly and that didn't work - only leaving it unplugged for 10 secs or more seems to work - so the fix requires a complete internal discharge.
I'm on the most recent firmware as well.What firmware version? My Grizz is on 05.32 which appears to be latest available for download.
On the multiple occasions where it doesn't want to start the charge, Jeep flashes blue for 5-6 secs then nothing happens (4XE isn't on any schedule). Have you also reached out to Grizzl-E? I've requested a return but since this was purchased direct, they are only offering an exchange.
