SnB4xe
There are many choices that will work. Remember, the charger is in the Jeep so the EVSE just needs to supply power to the charger on board the Jeep and communicate with it.So do we have a consensus on which level 2 charger to get? Seems like this thread is all over the place with no clear winner
Simple answer.....look to see if your utility company offers incentives or discounts. Many times they will offer 3 or 4 model choices so pick the one you like.
A plug in version is fine if you are only going to use it for your Jeep or a future PHEV model. If you plan on going full BEV at some point then consider a 48A hardwired unit or at least the circuit pre-wired for that rating so you can upgrade later.
Wallbox Pulsar Plus has a feature that allows it to circuit share so you can add a second unit later to share power in case a second EV is added to the household. ChargePoint does that too but you need their help to program them in their cloud. There are a few other manufacturers that have similar features.
ChargePoint is a premium brand.
EnelX is pretty good.
Clipper Creek and Grizzl-e are middle of the road and good choices for most users. Wallbox is a good choice also.
If you can get your hands on Aerovironment-RS or Siemens VersiCharge for a good price then those are nearly bullet proof. Those have real contactors inside and very little charging losses.
Probably want to stay away from "Amazon Specials". They get hot and performance suffers.
