Where do you mount your hi lift?
Jimmy_jak
Central Florida
2019 JLU Sport S
I have a hi lift jack and ordered the rear roll bar mount. After three months Quadratec can't get it in stock so I bailed.
Now back to square one. If you have your Jack mounted please post a pic. I need ideas. Thanks.
Chocolate Thunder
Jeremy
I’ve got the roll bar mount, ordered directly from dominion off-road. Works great. Maybe try getting it directly. No wait when I purchased.
1996cc
Oregon
21 JLUR 392
I did the same. Also trimmed the factory plastic to fit back in place.
sandygar4
Gary
Oregon
2019 Wrangler Rubicon
I used this one too. I used a fiber door casing shim pushed in between the shaft and the slide to eliminate any rattling.
1996cc
Oregon
21 JLUR 392
^ this is a must-do! I also added a plastic washer in one of the bolts (my jack is 25 years old, may have more play). With those changes and the neoprene Hi-Lift brand “boot” cover, it’s nearly silent. Without those mods, it’s annoying as heck.
ExitLeft
Wes
Philly ‘burbs
2003 Jeep Wrangler TJ
Mine has literally been sitting in the corner of my garage since 1999. I won it in a raffle and have never used it. Maybe I'll take it out someday and have a look at it. To be honest, it scares the hell out of me.
crbrenny
Chad
Palmetto, FL
2019 JLUR Sting Grey; 2021 JLR Gecko
Engineer
+1, i did this same way, ordered directly from Dominion. Its not introduced new noise inside either. i did trim the pieces and put them back over the jack mount though, i'll try to get a picture.
Chocolate Thunder
Jeremy
I trimmed the pieces and put them back too. I just took these as photos of the install.
I was amazed that I haven’t had a single solitary rattle and I didn’t use any shims, pads, or anything to dampen noise.
Jimmy_jak
Jimmy_jak
Central Florida
2019 JLU Sport S
Just ordered the Dominion mount. Thanks to all!
Jimmy_jak
Jimmy_jak
Central Florida
2019 JLU Sport S
aprez27
Andrew
Long Island NY
2018 JL Wrangler Rubicon
Had this one on my JKU, do you still have to remove the jack to lower the soft top?
Chocolate Thunder
Jeremy
I don’t have a soft top, only hard top. Not necessary to remove it for hard top removal.
JIMBOX
JAMES
FERNLEY NV
RETIRED
I have a "JACK CASE" for mine, but before that I always just put the HiLift(foot off) under the rear seat (JLU--no problem-
You should NEVER mount it OUTSIDE !
W.E.
JIMBO
