Oh,......nevermind.........I'm looking for something to put on like a cover.
why?...the hard top is the "cover"....just go barebackI'm looking for something to put on like a cover.
Do you mean roll bar padding like below?Is there any products out there to put on after you take top off to clean up the look of the side rails?
They are what they are. I use them only when the top is off, since they do not fit easily with the MOPAR Hardtop Headliner installed around the back windows. With the top on I use the regular bolts with D-rings and GPCA wide tie-downs to hold large velcro straps. The straps hold all sorts of things back there, so they don't shift when I drive. I do like the look and practicality when the top if off though. Everything needs to be tied down or the wind will take it...How do you like those things? Have you tied much to them? I keep looking at the quick release pro (not the d-rings) and thinking they could be handy but they look like they stand up taller than I'd like. Like u/Maplecs I like the smooth look. I'm not as extreme as they are, I'm fine with the bolt holes and such, but I don't know if I'd like how tall those GPCA things stand.
I like, own and use these. They are, IMHO, faster than using the FCA supplied wrench on the factory bolts, but much slower than putting a torx bit in a drill against the factory bolts. Towards that end of speed removal though, I wish these tie downs were designed with a torx bit in the middle so the owner could have the best of both worlds:Some people -- me included -- usually put something practical, like tie-down anchors when the top is off...
