Sidewalk
After leaving parked in the rain with the doors off, that's what I gotHa, I expect water intrusion sitting in the parking lot when it rains, so...
all bets are off when the valves go underwater
Yeah, but remember the context. Those check valves are located above the fording depth. Your original question was just around door-sill-seepage, and the sills are considerably lower.... Luckily the vehicle will be in for service this Friday, so I'll make sure they check the diff fluids at that time. Already drove 1500 miles on them through so hopefully no damage if water did leak in.
Was quoted $450 to have this completed, and was told that they can't check diff fluid because once some comes out, they need to refill it and they would need to charge me, at a minimum the $65 for the smallest size of diff fluid plus labor.Yeah, but remember the context. Those check valves are located above the fording depth. Your original question was just around door-sill-seepage, and the sills are considerably lower.
So as far as checking/changing diff fluid goes, if I just had water above the door sills, and had some seepage of, as you said, one or two cups of water under the doors onto the floor mats, I wouldn't be concerned at all about differential intrusion.
A dealer is probably gonna hit you for 400 or more for a front/rear diff fluid change. No need to incur that expense prematurely or over-complicate your life.
I don’t really buy into the cleaner air in dusty environments either. From off roading in dry conditions, the dust is 20 feet in the air. It’s everywhere. I guess if the snorkel air intake was spun to face the rear of the Jeep it may help some.This isn't really true. Snorkels aren't just for water, they also help the Jeep breathe cleaner air in very dusty environments like following other vehicles down dirt roads. But I do agree that most people that run them do it for the look instead of an actual need, kind of like a farm jack. Can't tell you how many of those I see, usually color matched to the Jeep, on Jeeps that have nowhere to actually use them on the Jeep.
And it's a real problem every time you have to stop and move a log out of your way.Usually the jeep is pretty water proof, not guaranteed though. Some people get leakage. Hit or miss. Also a quick splash through, probably be okay, swimming around in waterbkong term. More likely to get water.
unThis!
Until you try to take your Jeep through the Mississippi..... then you'll be thankful for your 200' breatherUgh. Snorkels are the ultimate poser mod.
Hopefully the drain plugs are "zero-way". The drain holes, however, are a different matterContrary to popular belief, the drain plugs are not "one-way". Surprisingly, water can come in through them also. Who knew?
And for the vast majority of Jeepers, snorkels are just for show. There are some legit reasons for one but almost no one has those use cases.
The one-way drain plugs was joke from my TJR which had the plugs removed and never replaced. If I crossed a stream or a lake water would come in and the kids would say we were sinking. It old them that was nonsense. They are drains and only drain one-way. Not to worry until the water came in through the doors (which were off at the time).Hopefully the drain plugs are "zero-way". The drain holes, however, are a different matter
