brazos
So I decided to install wheel spacers. The only times I’ve been worried were when I thought I was gonna tip over, plus I like the look of a wide stance.
Researched it; definitely not a place to pinch pennies.
Ordered Spidertrax. Wrong ones. JK has same bolt pattern, but smaller studs.
Returned them, ordered new ones.
Also ordered a deep 22mm socket. Thought I’d be smart and get a heavy-duty impact one.
Doesn’t fit in the holes in the spacers.
Borrowed a short 22mm from neighbor. Installed a spacer. Turned all 5 nuts in finger tight. With red loctite.
Went to tighten up. Short socket lost purchase just as things snugged up.
Began removing nuts. Socket barely grabbing nuts.
Then the red loctite started setting up. Hard. Finally got it apart.
Gave up for the day.
I think I’ve done everything wrong that can be done wrong, and hope for clear sailing when I get a deep thinwall socket Monday morning.
A mechanic I’m not.
A mechanic I’m not.
