Old Dogger
- Bill
- Nov 15, 2021
- Cave Creek Arizona
- 2013 JKR, 2018 JLR
- Occupation
- Retired High level Management.
This is a topic, that it seems like has been discussed and mis-understood on vehicle forums ongoing.
First off, one doesn't need to be concerned about offset. With a wheel the concerns are the size 17",18", or larger, or smaller. mounting bolt pattern, proper mounting hole to stud size, Rim width and back spacing. And let's not forget price..LOL Most by far will use a 17", or 18" wheel, with a Rim width of 8.5" to 9.0", with a Back Spacing of 5.2 to 4.5. Most any size tires that we choose to run, will work good with this combination.
Below is more info that may help, example how to measure Back Spacing.:
^^^ The reason that knowing a offset number, is not really needed, is Because it changes by Rim width. EXAMPLE: A 8.5" RIM WIDTH, WITH A BACK SPACING OF 4.5 SHOWS A OFFSET OF -6. BUT WITH A 9" RIM WIDE, AND THE SAME BACK SPACING OF 4.5 SHOWS A OFFSET OF -12.
SO PLEASE, DONT BE CONCERENED ABOUT OFFSET. CONCENTRATE ON RIM WIDTH AND BACK SPACING, PLUS WHAT HAS BEEN MENTIONED ABOVE. BUT FOR THOSE OF YOU THAT FEEL MORE COMFORTABLE WITH OFF-SET! THERE IS CHART ABOVE FOR THE CONVERSION.
