Wheel brand question - Method vs Vision vs Fuel
Captain Skip
Skip
New Hampshire
2020 Wrangler JL Sport S
Happily retired
I'm narrowing down my choices for wheels for my JL. Sport S, no lift - I'm planning on going with either 285/70/17 or 265/70/17 Toyo Open Country ATIII's for the tires. I've narrowed down the wheel choices to the Method 316, Method 704, Fuel Shok D665 or Vision 351 Flow. Either titanium or gray, to go with my Sting Gray JL. I'm seeing lots of good reviews and info on the Method brand wheels. How does Fuel and Vision compare as far as quality? The Method 316 is running $199 a wheel, the others are all in the $240 to $265 range so they're comparable. I only plan on buying once so I don't want to buy wheels that I don't like and have to buy something else down the road. I'm figuring probably going with a 0 offset, just need to grab a measurement on the existing 245's to see how much more the 285's would stick out under the fender. Any thoughts, experience or comments? Thanks.
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel method316
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel mr704_gray_white
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel shok_gray_white
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel vision-flow-351-wheel-5lug-satin-black-16x8-500_9089
limeade
Guy
Reno, NV
I have Vision Nemesis on my 2018. Got them due to them being a bit lighter than others, looks, and features (has a removable rash ring). I've had no issues with them over the last year while running 37's on them. The Trail Grappler's I have mounted on them have balanced very well, taking very little weight and have low road force balancing numbers. I believe it was between 2-4 ounces and RF numbers between 19-22 lbs. Based upon how that tire/wheel combo has balanced, I would say they are well made and run very true.
blnewt
New Mexico
Just ask @cosine he knows!
All nice choices, I like fewer spokes (easier to clean and always been a fan of 5 or 6 spoke sets).
So my vote is the Fuel as long as the offset is good. I'd shoot for a +10 give or take a few mm.
Wanted33
Jim
Down south in Dixie
2019 Sting-Gray Sahara
Dang Brad, I was going to say the same only using different words. Like you I prefer fewer spokes for ease of cleaning.
Skip, I'm of no use in helping you pick. I like them all. :)
rickinAZ
Rick
Phoenix
2021 Rubicon EcoDiesel (11th Jeep)
If you like them all, go for the one that is (materially) lighter if there is a weight difference.
Captain Skip
Captain Skip
Skip
New Hampshire
Happily retired
Only problem I'm finding is with the 285's the Methods are 0 offset so the tires will poke out up to .8". The Fuel is either +1 or -12. The -12 sticks way out, 1.27" according to the offset calculator. The Vision is either -12 or +30. Same thing with the -12 as the Fuel, going +30 moves the tire in almost 2" and just over 1/4" further in than stock on the outside. If I go with the 265 instead of the 285 then the 0 offset puts me .4 further out and .4 further in. I wanted to go a little taller with the 285 but I really don't want the tires sticking out past the fenders so maybe I just suck it up and go with the 265's, even though they're only .10" taller than stock 245's. I thought about going to 18" wheels as this will give me more options on the tires, like 255/70 and 275/65 but the 18" wheels limit me to just Fuel. I know I want a gray/titanium wheel and I don't want a beadlock/simulated beadlock, that's why I picked the ones above. Decisions, decisions.....:headbang:
Oh, wait a minute - EDIT - just found that Fuel offers the 18" with a +20 offset, calculator for the 275/65/18 shows it with the outside just .19" further in but it moves the inside 1.39" further in. How much room is there to move the tires in before they start rubbing and encroaching on suspension parts or the frame?
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
The lighter the wheel, the better. Also, the JL hub size is 71.5 mm. As a secondary consideration, if any of these wheels match then I'd go with that one but larger is okay, too.
Oncorhynchus
Moishe
San Jose, CA
2018 JLU Sahara Sting Gray 3.6L
+1
It’s a minor chore to wipe off the brake dust in between the spokes. But if the wheel itself is dark then the brake dust and grime may not be so noticeable.
blnewt
New Mexico
IMO I'd stick with 17s, more wheel & tire availability and a bit taller sidewall.
Here's my fit at the fender edge w/ 295/70/17s on a 17x8.5 +10, if you went with a 285 you'd be about a 1/4" in from my set if you find a +10 offset.
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel 100_4024.JPG
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel 100_4025.JPG
Don't know if you've seen these but have a nice look and a +10 offset, According to the Quadratec specs these have a shipping weight of 31 lbs vs the Method wheel that's at 41 lbs.
https://www.quadratec.com/p/rugged-...l-17x8.5-wrangler-jk-jl-gladiator-jt-15301.61
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel 1612732198841
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel 1612732230836
Captain Skip
Captain Skip
Skip
New Hampshire
Happily retired
Thanks Brad, the photo of your Sting Gray helps a lot. It's a lot better to see the real thing rather than using the online calculator. What wheels are you running? The Quadratec/Rugged Ridge wheels look interesting, I'll have to take a look at them.
blnewt
New Mexico
Here you go Skip, just to show different lift/fender changes. The wheels are ATX Ravine (no longer available)
Bone stock, w/ new wheels/tires, w/ Rubicon suspension swap, then high fender kit. The good thing about the last photo, you can easily run 35s but still keep a lower center of gravity :)
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel 100_4015.JPG
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel 100_4023.JPG
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel IMG_0253.JPG
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel IMG_0502.JPG
Captain Skip
Captain Skip
Skip
New Hampshire
Happily retired
Jeep Wrangler JL Wheel brand question - Method vs Vision vs Fuel 90E71B43-8B08-4463-8FDF-18C24D6F5FA2
Thanks for the additional photos. You sir have exquisite taste in vehicle color!
Okiedokie
Jennifer
Oklahoma
2019 Sting Gray Sahara
Skip, I am in the same dilemma. What did you end up choosing?
Captain Skip
Captain Skip
Skip
New Hampshire
Happily retired
Nothing yet....I think I'm going to hold out for the Vision 351 Flow in grey. They have a +30 offset so they're reasonably close to OEM. The Commander in Chief won't release the funding for new tires until I wear out the ones that came on the JL....... If you see black marks on the road in front of my house I have no idea how they got there.
