Cypher
Looking for advice from others who have swapped out the factory wheel and tires on a Rubicon. I plan to run 315/70/17 and have narrowed it down to the Ridge Grappler and the BFG K02. (I know there are other good tires, but these are the ones on my short list).
I have narrowed my wheel choices to the Dirty Life DT-1 9303 with a -12 offset, and the Quadratec 41 with the +10 offset.
Has anyone run a similar combo, and what are your thoughts on them? What type of MPG hit did you see?
Here is some rough data on the combos.
DT1 weight - roughly 46lbs
Quadratec 41 - roughly 26lbs
315/70/17 K02 roughly 65lbs
315/70/17 Ridge Grappler roughly 71lbs
Factory wheel and tire weight = roughly 80lbs
DT1 + 315 ko2 111lbs
DT1 + 315 RG 116 lbs
41 + 315 ko2 91lbs
41 + 315 RG 96lbs
I will have the full metalcloak undercloak, front and rear diff skids, lca skids, winch guard, Roam rock sliders, and will have winch. (Quite a bit of added weight)
My main concern is with all the added weight already, should I try to keep the wheel and tire combos as light as I can? I will not be running the dt-1 as a functional beadlock, so no bnifit there as of now. (But can in future if I choose) I also want to make sure the wheels are not too far out. Looking at the specs alone and the online tools the Quadratec 41 with the +10 offset may be a better overall fit for the JLUR, as the -12 pushes the tires out quite a bit. With getting rock chips already with the factory setup, pushing the tires way out seems like a bad idea. Also, will I end up with faster wear on the steering components with -12 leading to a faster onset of death wobble? Also the dt-1 has a larger hub bore, so is this something that may lead to more balance issues?
Looking for anyone's opinion on this that wants to chime in. I am leaning to the Quadratec 41 with the Ridge Grappler, but I always have, and still do like the DT-1.
41 + 315 ko2 91lbs
41 + 315 RG 96lbs
