Threxx
- Kyle
- Dec 14, 2017
- Memphis, TN
- 2018 JLUR HT 3.6AT
It has almost become status quo at this point for manufacturers to take an existing V6 or V8 vehicle and start offering a motor with two fewer cylinders offset by the addition of a turbo, which almost always generates substantially more torque at low RPM than the naturally aspirated motor they replaced, and often provides better fuel economy as well.
So I had high hopes for the 2.0t in the Wrangler, expecting it would offer similar benefits over the Pentastar V6.
However the reviews are in, and so far every review I've watched or read indicates the 2.0t provides less torque at low RPM than the Pentastar, or similar at best. I've seen some people write this off as "oh well it's a small displacement turbo engine, what did you expect?"... but that was par for the course 10-20 years ago. Modern turbo engines generally don't have turbo lag, and don't have to wait to spool up. And to add to that, the Wrangler 2.0t has the added benefit of a 48 volt BSG system, which would only help off idle torque that much more. Most other modern turbo powertrains on the market aren't using a BSG system yet.
So what's left? Why does the 2.0t exist? The articles I've read, including the one on the front page of this site (which I've been reading for a long time, but just now decided to register to comment), point to its expected improved fuel economy.
So you have 18/23 from the 3.6 V6 using 87 octane, right? Average the two and you get 20.5 mpg
Then you have 21/24 from the 2.0t I4 using 91+ octane. Averages out to 22.5 mpg.
Here in Memphis, looking at Gas Buddy, the best price today is $2.04 for regular, and $2.43 for premium (at Costco).
Let's say you put 20 gallons in your Wrangler's tank. That's going to cost you $40.80 for the V6, and $48.60 for the I4.
With 50/50 mixed driving, you'll get 410 miles of range in the V6 and 450 miles of range in the I4.
So in the V6 you're getting 10.05 miles per dollar.
In the I4 you're getting 9.26 miles per dollar.
So there goes the fuel economy benefit. The I4 actually has a higher fuel cost, unless people find you're able to run 87 octane in it without hurting the fuel economy much... but you're definitely going to lose some power if you do that.
Even if you drive entirely in the city, where the MPG difference is more in favor of the turbo 4, it still costs more to run the turbo.
V6 = 8.82 miles per dollar in the city
I4 = 8.64 miles per dollar in the city
I'm really struggling here. What's left. Why did they bother to put the turbo 4 in the Wrangler? Refinement? According to the reviews (and common sense based on most other small turbo motors out now), the I4 is less refined with the exception of the start/stop system, which being BSG, works more seamlessly than the ESS in the V6.
Uh... maybe reliability? Well, I don't think anyone has any data on this new turbo 4, but historically small high strung turbocharged motors aren't renowned for running hundreds of thousands of miles without issue. Add to that the complexity of BSG system (more stuff to break) and the pretty decent reputation of the Pentastar, and while we can't be sure, my money is not on the 2.0T outlasting the 3.6 on average.
The one thing I can think of that will probably be better in the 2.0t is modding. I suspect like many factory turbo motors, you'll probably be able to spend a few hundred bucks on a tune and you'll be making quite a bit more power than from the factory. Though at what risk to reliability and warranty remains to be seen.
Anyway... I'm not trying to be a pessimist here. I'm just honestly asking, what reason is there to opt for the 2.0t? Do you think Chrysler had higher hopes for its fuel economy or power and it just didn't pan out?
