What would you do?
Mac
MA
2020 Gladiator
Rubitrux has low mileage take out 3.6 engines for $2700 delivered if they end up not covering it.
R00STER
Rich
STL
2021 JLUR 3.6L - 6sp
....I would not use a 3.6 other than stock. If you are definitely seeking performance, then use a performance built engine.
Is there a way to build the 3.6L to handle FAI before you add the FAI, or would you being throwing good money after bad?
I wont't give up my manual, but I want more power out of my little 3.6, especially in the 2-3k range. I was going to go Eldebrock, but if I need to swap pistons, rings and heads before I install, then it might not be worth it.
Carolina Jeeper
Rollie
North Carolina
The pistons and rings are key components that aren't up to the task in my opinion. The increase in compression and combustion pressure and temperature can push the pistons and rings to failure. Not to mention the head gaskets.
The top compression rings can get hotter causing the ring gap to close causing broken piston rings. Or the top compression ring can seize in the cylinder and can rip the top of the piston off.
I think it's better to build an engine with the intended performance level it'll be subjected to. Compression Ring gaps need to be increased and head gasket type should be upgraded. Cast aluminum pistons can't take the heat and pressures that hyperuetectics and forged pistons can.
It's your engine, but you can find these common failures in plenty of documents tied directly to performance adders like turbo chargers, superchargers or such. Yes, you may get away with it with 100% factory parts. Just be aware of the risk.
AZtorque
Cave Creek, AZ
2021 JL Rubicon Diesel, 06 Rubicon LJ
My JL diesel engine is stock but I do also have a LS 5.3(LH8) / 4L60E conversion on my 06 LJ Rubicon. I had 186k miles on my original 4.0 and talked myself into an engine conversion. I would not do it again. I had the work done at a professional shop that specializes in Jeep conversions and has had several Jeeps at SEMA. Even with all their experience, things like tuning & cooling produce a whole host of gremlins. Count on several trips back to the shop to tighten up loose ends. Then, after you get the loose ends worked out, finding local shops that will to touch a "Frankenstein" for general work can be difficult. I've had to become a pretty good shade-tree mechanic as a result. Whatever cost you think it will take to get the engine conversion completed, add $5-$10k in additional expenses. My LJ is a beast and very fun to drive but the investment in time and money was not worth it.
JeepinJason33
Denver
2021 JLU Rubicon V6 with Etorque - just starting build. 2019 Grand Cherokee SRT, 2001 XJ mild build, 97 TJ supercharged, Atlas, cage, 1 tons, OBA etc. 83 Cherokee Chief Restored
Could not agree more! Everyone thinks these conversions are easy and cheap to do. Never turns out that way if you want it right. I only had 45,000 miles on my TJ and went with a bolt on supercharger that ended up costing about 4k all in. Everyone was telling me I could swap a V8 for the same money... Never had a problem with the supercharger or added expense behind initial cost for supercharger, pulleys, and gauges.
Bocephus
Bocephus
Virginia
'18 JLUR
Sam’s Decorative Automotive Button Emporium
Hey I appreciate that info guys, that’s what I was worried about - engine adventures. I ended up putting a 3.6 back in it and sold it, along with a car, and got into a 392. It’s pretty great, life is good. Trying to work up the courage to go beat on it on local trails!
FJL40
Desert
2021 Rubicon 2dr 6spd
Stroked and built K series Honda 4cyl Turbo. Great fuel economy, amazing reliability, easy to acquire, and power/torque for days. You will need a standalone ecu.
gerlbaum
Greg
Arizona
2021 Wrangle Sport Diesel
I put a 6bt into a ‘72 k10. Still have it. The last 10% took 90% of the time and budget. Lol I remember the day I got the engine/trans/tranny in and mounted for the last time. I thought “I’m almost there!”. 1.5 years later I was lol - and that was all mechanical.
Outrun
PNW
2021 392XR
Build the 3.6 into a low compression forged internals and twin turbo.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Was it covered by Magnusson?
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
I thought of doing a super charger or a turbo, in the end I said when the 3.6 is done, I will swap a Hemi or an LS into the Jeep.
Zandcwhite
Zach
Patterson, ca
2019 jlur
I think you might be the first person ever to say k series and torque for days in the same sentence. Typically a k series makes 30-40% less torque than horsepower and doesn’t make shit for power or torque below 3k rpm. Sure if you turn up the boost enough it will make more power than any of the stock offerings, but you’d have to push it well past 600 horsepower to match the torque of the 392 or diesel stock. Even then the torque would be too high in the rpm for technical trails, unless you go the Toyota build route and throw in a doubler. Not the route I’d go in a Jeep build, but to each his own.
Bocephus
Bocephus
Virginia
'18 JLUR
I ended up putting a 3.6 back in it and selling it, and eventually got the 392 jeep.
Bc I traded my car in too, the 392 is my daily driver. I put the teraflex spare carrier on it, MC front LCA to dial in caster, got my old winch and light mounted, and 35s. I was kinda pleased that my tire/wheel package was net zero for weight gain. Tires are 10lbs heavier, wheels are 10 lighter. I had never run 35s before, honestly super stoked with them. Feels light, and I think capable enough for the trails I want to get on. For now at least.
From here I’ll get skids and probably rails. I hope to keep it fairly light bc it pulls daily driver duty.
This engine is truly great in the jeep, just man-handled the weight. It’s no racer obviously, but feels nimble and quick. Just super capable.
PSC Motorsports
