How about this?I was wondering if anyone knows what kind of steps I can use to attach to my 2019 Rub Rails? I just took off the old plastic OEM ones off and installed these in their place. Problem is I need a step to get in and out of the Jeep better.
Thank you,
Ace Engineering makes a slider that is a tube rail. It bolts directly under the factory Rubicon rail.I was wondering if anyone knows what kind of steps I can use to attach to my 2019 Rub Rails? I just took off the old plastic OEM ones off and installed these in their place. Problem is I need a step to get in and out of the Jeep better.
Thank you,
Nextventuremotorsports makes weld on tube rails that can be used as a step.I was wondering if anyone knows what kind of steps I can use to attach to my 2019 Rub Rails? I just took off the old plastic OEM ones off and installed these in their place. Problem is I need a step to get in and out of the Jeep better.
Thank you,
