It depends on what is on the window sticker/what the manufacturer labels it as.Question from overseas - moving to USA
Does a 2018 manufactured show up on records as 2018 or 2019 if bought new in 2019 ?
ie in UK would show as 2019 because this is when vehicle is 1st registered
This isn't the case.Personally, I would not buy a 2018 at this point as the depreciation has kicked in, and you can get 13% off MSRP ordering new. That said, I think 20%+ off MSRP is the only way I'd get one.
The difference in value from year to year is around 6% according to KBB holding all other data constant in my zip code and the delta shrinks as you get to the 5+ year marker. KBB is typically pretty close on mass production vehicles with plenty of transactions.This isn't the case.
I looked at this a few months ago on JKs that were 3-4 years old and 2-3 years old. I used KBB to compare models that had the same mileage but were a year apart, a 2014 to a 2013 for example. The year didn't matter. The values were essentially the same. Same model, color and same options were the same trade-in value. For example, 2014 and 2015 UL Sport S are both $23.1. KBB gets their valuations from actual transactions so the numbers are what they are.
Not saying anyone should't get a 19' over an 18'. Just don`t do it because you think it will be worth more.
I ran numbers on a 16' and 17' JKUS and the difference was about $500. Didn't see anything close to your numbers for my zip.The difference in value from year to year is around 6% according to KBB holding all other data constant in my zip code and the delta shrinks as you get to the 5+ year marker. KBB is typically pretty close on mass production vehicles with plenty of transactions.
So I still think going with the ‘19 is smarter unless you can make up most of that difference. If you’re not trading within a couple of years like I do it won’t matter as you said they’re worth almost the same after five years. But for me if I get an ‘18 for the same price as a ‘19 and trade in two years I’m leaving $3-$4k on the table. So in my case I’d only buy an ‘18 if I can make up that difference.
I believe Koons has all their 2018's on sale for 8% under without Tread Lightly.In Northern Virginia - 7% under invoice w/o Tread Lightly - 8% with it.
Might be different on sports I guess or in your area. I only checked Rubis ( base equip ). I think the S holds the value quite a lot better than Rubi. I checked Scottsdale AZ. Made sense for me to get the Rubi as it had a lot on it that would have costed me more after market.I ran numbers on a 16' and 17' JKUS and the difference was about $500. Didn't see anything close to your numbers for my zip.
Good point - I was referring to 2019s. I think you're right, for 2018's still on the lot you can probably get closer to 10% as the weeks go on.I believe Koons has all their 2018's on sale for 8% under without Tread Lightly.
