What mix of Metric and SAE on JL?
Techbrute
Tim
DFW
2020 Jeep Wrangler Unlimited Rubicon, 2000 Jeep Wrangler Sahara
So how much of a mix is the current JLU between metric and SAE? Of course Torx is actually metric-only, but do we still need to bring two tool kits for the trail for the rest?
Focker
Sacramento, CA
www.ducati.ms
2020 Jeep Rubicon
General Manager
Everything I have found "so far" from the factory is metric. It seems only the stuff we buy aftermarket confuses the issue with some goodies being SAE. I am only carrying metric along with a Crescent wrench currently.
D60
CO
JL
That'd be an all-sixteenths, technically. Duh ;)
As for the OP, I can't imagine anything on the JL is intentionally fractional from the factory. Guys may often confuse 8mm;5/16", 14mm;9/16", 19mm;3/4", 22mm;7/8" etc
plex
Cincinnati, OH
Weekend keyboard mechanic and beer drinker
I found there are certain factory parts, if sourced from an US company and built here, then they may have SAE parts. For example, the factory Dana axles have bolts that are 1/4". 1/4" is definitely not equivalent to any standard metric size.
blnewt
New Mexico
Just ask @cosine he knows!
The oil drain plug is 1/2", oil filter cap is 15/16", the LCA nuts and bolts are 13/16" & 15/16". Those are the SAE fasteners that I've found thus far, but I'm sure there's the typical mix of metric/SAE.
Most postings for the aforementioned fasteners list metric, but for those specific ones SAE is the correct fit, especially important on the 190 ft. lb LCA bolts :)
Techbrute
Techbrute
Tim
DFW
So, I'll just out myself as a moron... What's LCA?
I look at acronyms all day long, and when they aren't technical, I can't remember them in the right perspective.
  • Like
Reactions: J0E
Maverick909
Inland Empire
www.instagram.com
Lower control Arm LCA and UCA upper control arm ive notice 90% is Metric and i only carry metric and a couple SAE for the aftermarket parts that i know the sizes for
blnewt
New Mexico
I vote for suspension hardware being metric.
I vote for ALL hardware to be either Metric or SAE, just pick one, although I too prefer metric :)
plex
Cincinnati, OH
I am pretty sure LCA bolts and nuts are 21 mm and 24 mm, almost all the other bolts on suspension are 18 mm.
Source: Mopar torque specs, looking at the 4th column.
blnewt
New Mexico
I try both SAE and Metric prior to any wrenchwork on Jeeps, for the LCAs the sizes I listed render no slop, and at 190 ft. lbs you sure as hell don't want any :)
Go ahead and try both, I guarantee you'll be using the SAEs :)
Try it on the oil drain & filter cap too :)
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
Ehhhh this is gonna be awkward but I’m still using metric for nearly everything factory. 21/24mm are perfect for the control arm hardware.
Brett
blnewt
New Mexico
Brett
Not awkward Brett, like I said, if you have both on hand give th SAEs a try :)
