Wrangler man
- Howard
- Aug 24, 2019
- Palm Springs
- 2020 JLUAD
Finances were tight when I was forced to do a lease on a stock JLU, with all season tires. Regardless of what kind of tire it is, to get the best performance you must always air down to 12 to 15 PSI disconnect your swaybar links.This will increase comfort, ride, and off roading ability by at least 30%. No one says it's fast to air down all the tires. Get a 19 mm wrench set disconnect your swaybar links each time you hit the trail, but it's easy, and FREE. I did it for a year, slowly driving to the nearest gas station to air back up at the end of the day. Hint just practice disconnecting the links in your garage, driveway before hitting the trail, After the 1st year I spent $100 for a portable legit air compressor,
(Amazon)and a quick disconnect system for $140.00. (Northridge 4x4) Which I easily installed myself in a couple hours and then took off and gave to a friend when the lease ended. Don't think you're limited to sand or dirt you could do moderate rock climbing if you choose your lines correctly. 100 times better to be a skilled driver in a stock Sahara, than a Weekend Warrior without a clue in a Rubicon. Live in SoCal me too.. Check out Alltrails vids on YouTube many to choose from. For legit wheeling pointers watch Kevin and Britney with their Lite Brite channel on YouTube. Britney picks the best lines of anyone I know and her husband Kevin is the best at wheeling up those lines. You will learn a ton. , learn your lines! Get your wife or kids involved, They can learn how to pick the lines for you. A good spotter is a must when you're starting out as a novelist. Good luck and have fun
