Drop a regular nut and washer down into your frame and the use of them becomes brilliant.The are ugly, and fairly visible. The odd thing is with the access hole on the outside of the frame, they seem Unnecessary.
about 2 seconds with a can of black spray paint will soften your sufferingThanks for the responses. They just look out of place.
I was a uhaul hitch mechanic for years. I have dropped many a bolt into a frame. Fortunately, it was somebody else’s frame. LOL. Back in the 90s we used nuts with a wire welded in one side. When you impact the nut it sucks the wire into the access hole. Getting them back off was a mother stinkerDrop a regular nut and washer down into your frame and the use of them becomes brilliant.
It is an aid for installation of the nut. Makes life easier for the operator on the line.I've only had my Jeep since July and today I noticed this on each side behind the front axle. What are they? Something that should have been removed after shipping?
It makes life easier for you as well when you are installing a lift kit by yourself because your friend douched out and can't make it.It is an aid for installation of the nut. Makes life easier for the operator on the line.
We must have the same friendsIt makes life easier for you as well when you are installing a lift kit by yourself because your friend douched out and can't make it.
