Yes, in the tub area. Keeps things from sliding around.Where and what is it's function? Does it go in the tub area?
yep that's where mine was tooIt was in the clear bag that protected the freedom top case. I think... I can't remember 100% as I was excited just opening things.
I found ours there also, check every item that came with your JLU. I also did a visual of every nut & bolt that I could see from front to rear, for loose or missing items. I'll admit that it was assembled at the factory with great care, no scratches, nicks, missing nuts, bolts, or screws from what I've seen so far. I also checked the torque on the lugs and I will have the factory alignment checked out soon.It was in the clear bag that protected the freedom top case. I think... I can't remember 100% as I was excited just opening things.
Wow that's detailed! I wish I would have checked it better. I have a scratch in my top I don' think I put there. It had about 30miles on it when I bought it so I'm sure the sales peeps took it for a spin or ten.I found ours there also, check every item that came with your JLU. I also did a visual of every nut & bolt that I could see from front to rear, for loose or missing items. I'll admit that it was assembled at the factory with great care, no scratches, nicks, missing nuts, bolts, or screws from what I've seen so far. I also checked the torque on the lugs and I will have the factory alignment checked out soon.
