What is this (found in the glovebox)?
CarbonSteel
2023 Ford Bronco Wildtrak
I had to travel right after purchasing my Rubicon and have not had a chance to go through everything in fine detail. I opened the glove box today to look at the owner's manual and there was a large piece of textured rubber folded inside and simply "sprung out" when I opened the door. It does not seem to fit the glove box and was wondering if anyone can ID it. It is about 1/16" to 3/32" thick, about 6" wide and about 16" long and is textured on both sides:
Rahneld
Ronald
Boston
JL Wrangler
Cubby hole in the rear storage area.
The image, flipped over, sure looks like the shape of the bottom of the carbo tub.
I had to buy mine, even it is has walls.:)
https://www.quadratec.com/p/mopar/rear-cargo-tub-liner-jeep-wrangler-jl-diesel-engines-82215670ac
Edit: the above appears to be the cargo tub liner for diesel engine JLs.
This is the one for gasoline driver ones:
https://www.quadratec.com/p/mopar/rear-cargo-tub-liner-jeep-wrangler-jl-gasoline-engines
I know...engine choice affecting cargo tub....not my first guess either. Thanks @Tech-Dude
HealthRebel
Jerry
Colleyville, TX
2020 JLRU Ocean Blue
Funny. I took the same picture and texted it to my sales person the 2nd day I had my Jeep. Not sure why it wasn't just in place.
I also received a bag of short black rubber tubes and some metal pins in a bag. I was told these are for the auxiliary switches if you got the towing package.
CarbonSteel
CarbonSteel
I have that bag too. How do they work on the aux switches?
Neanderthalman
Greg
Ontario, Canada
The aux switches are connected to wires that are bundled up under your passenger side dash and in the engine compartment. If you want to hook up a device to those wires (so that it's controlled by the switch), the metal "pins" are a crimp sleeve to make the electrical connection (called a butt splice), and the tubes are heat shrink tubing that covers up the exposed metal.
Slide the heat shrink over the wire BEFORE crimping the butt splice, then slide the heat shrink over the splice and hit it with hot air from a heat gun, hair dryer, or in a pinch, a lighter.
CarbonSteel
CarbonSteel
Thank you @Neanderthalman!
JO DYRT
Orange County, CA
www.clickonpc.com
2018 Wrangler JLU Sahara
IT Professional
Jay 13
Jay
Toronto
JLUR
I’ve been trying to post on here, forgive me I’m new to the Jeep community....but I have that and this......what and where does this go??????? When I picked up my new JLUR 3 months ago it was in there and dealership had no idea what it was......Can anyone help?
Thanks in advance
Jay
Rahneld
Ronald
Boston
JL Wrangler
Mopar 82215670AC Rear Cargo Tub Liner for 18-19 Jeep Wrangler JL with "Diesel Engines"?
"Note: Only compatible with the Diesel engine applications"
Am I missing something?
Wow Joe. I think that's a good catch on your part. I did not mean to link to one for Diesel Wranglers only, any more than I thought a different engine would affect the cargo tub.
This seems to be the one for gasoline engines. I am a gasoline driven JLU owner.
Rahneld
Ronald
Boston
JL Wrangler
Thanks in advance
Jay
I think it covers the detector for I believe the adjustable cruise control sensor when you otherwise take the windshield down.
Jay 13
Jay
Toronto
JLUR
That makes sense. I was looking at that earlier as the shape of the sensor on the windshield i
Hmm that’s a possibility.....other words would it be fair to suspect everyone has this lying around in there cabin to use if/when they put windshield down?
