So the -18 wheel has the large Li- on the outside - right? Thanks‘Wheel offset is the distance in millimeters from the center line of the wheel to the mounting surface. If the mounting surface is closer to the face of the wheel it is known to have a positive offset and if the mounting point is closer to the inside of the wheel it has a negative offset. Center or no offset is when the mounting point is directly on the centerline of the wheel.’
Wheel offset will “push or pull” your tires out or in from stock......
Your stock rims are 7.5 inches wide with a 44mm offset.
This calculator can help you.....
https://tiresize.com/wheel-offset-calculator/
I don’t understand the question . “Li”?So the -18 wheel has the large Li- on the outside - right? Thanks
I was talking to a guy from Tire Rack today and said “there’s absolutely no way you can have a negative offset wheel without a lift”... which doesn’t really sound right to me. In fact not only did he say I should try to get as close to stock as possible (no less than 30), he said I should try to go higher. This really confused me because I thought that would push the wheel closer to the vehicle and cause clearance issues; when I questioned him on this he said no, the negative would cause clearance issues when turning the wheel. That still doesn’t sound right and I’m having trouble wrapping my head around this I guess... I really thought the key to lateral clearance (not tire height/fender clearance) was backspacing, which is calculated from width and offset. How does more backspacing = more clearance?As mentioned, in the JL 5-127 bolt pattern the only offset offered is ET-18 which on a 9.5:" wide wheel is ~4.5-inches of backspace.
The wheels will most likely work for you depending on tire size just bear in mind that the Armory wheels are going to sit about 3.5-inches further outwards when compared to where the O.E. wheels sit now.
Time to educate yourself...watch this:I was talking to a guy from Tire Rack today and said “there’s absolutely no way you can have a negative offset wheel without a lift”... which doesn’t really sound right to me. In fact not only did he say I should try to get as close to stock as possible (no less than 30), he said I should try to go higher. This really confused me because I thought that would push the wheel closer to the vehicle and cause clearance issues; when I questioned him on this he said no, the negative would cause clearance issues when turning the wheel. That still doesn’t sound right and I’m having trouble wrapping my head around this I guess... I really thought the key to lateral clearance (not tire height/fender clearance) was backspacing, which is calculated from width and offset. How does more backspacing = more clearance?
