2nd 392
After break in do you use synthetic? Regear Monday, little time to decide. Also- having Jeep do the install in hopes of less warranty issues ( ) , do you happen to know if the recommended non-synthetic Lucas meets factory standards? Thanks. Edit- or the best synthetic that does?I run conventional 85W-140 in my axles to break them in--as many gear and after market axle manufacturers recommend, however, the problem with conventional oil is cold weather and the OP is from Alaska. I would not run conventional oil in the temperatures that he is likely to see.
In addition (and no disrespect to any vendor that recommends using conventional oil), but there are millions of axles that come from the factory with synthetic gear oil. Short of a poor design, these axles last hundreds of thousands of miles with no issues running synthetic oil.
Below is a video that compares conventional gear oil versus synthetic in extremely cold weather.
From the video, according to SAE J306, here are the lowest temperatures these viscosities can be used:
75W-XXX = -40°C or -40°F
80W-XXX = -26°C or -14.8°F
85W-XXX = -12°C or +10.4°F
