What is the adjustable switch for?
Deerhorn
Jim
Jamul, CA
Ram 3500
It is the one in the middle of the picture just to the right of the headlight switch. There are two roller switches. The right roller switch is for the dash and dome lights. I cannot find what the one next to the headlight switch is for. I'm stymied!
Biohazard
Nathan
Bristol, TN
2018 JLUR (sold May 2020); now own 2020 trd pro Tacoma
Floor lights. They are pretty dim to start with, which is probably why you didn't notice. Wait until it's dark, then check it out.
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
That dial regulates the muffler bearings on Tuesdays and Thursdays. On all other days it is used to tune the flux capacitor.
or it could be for the floor lights.
Buckster
Palmetto, FL
'19 billet silver JLUR '16 Grand Cherokee Overland
Power Generation
Here we go again....it’s the hydraulic actuator for the exhaust resonance p-239 modulator.
Adventure.AS
Port Dover ON Canada
2020 JLUR
RTFM
"Dimmer Controls
With the parking lights or headlights on, rotating the right dimmer control upward will increase the brightness of the instrument panel lights. Rotating the left dimmer control will adjust the interior and ambient light levels."
GreyFox
Brandy
Ohio
17 JKU, 19 JL
RTFM
"Dimmer Controls
You're no fun:punch:... Of course I did just have to Google RTFM:facepalm:...For what it's worth, by saying you're no fun I mean you didn't give a crazy response:giggle:
MotownJLU
Metro Detroit, MI
2019 JLU Wrangler, 2011 Chevy Suburban
I guess it's more obvious on a Rubicon that has the courtesy floor lights that the Sport doesn't seem to have. The Sport does, however, have lights near the door handles that hardly produce any light at all. That dial makes those lights brighter and dimmer (although they hardly produce any light even at the brightest setting).
dezeinstein
Los Angeles
2018 Audi TTRS, 2020 JLUR Sahara Altitude
It tightens up the steering at freeway speeds.
KnG818
Ma
18 Rubicon
Catch-can thrust adjustment, allows more/less oil burn off when rock crawling in reverse.
EDH_JL
State of Jefferson
2018 JL Sport
I opened up the switch to see if it could be modified to actually be useful or move the overhead light control from the right to the left switch. Not possible.
