What is JLU's actual fuel tank capacity?
Rubicon_LA
Los Angeles
2018 JLU Rubicon
Tried to do a quick search here, but can't find the answer. I read everywhere in specifications that it's 21.5 gallons. For some reason I can never fill more than 17.5 gallons in my tank. I drove till almost completely empty, when I had 1.5 miles showed left, and the fill up was 17.6 gallons till full. I usually don't drive till fully empty, always filling up when I have a quarter of tank (or about it) left, and then I can only fill 15 something gallons. Is the actual tank size in JL less than 21.5 gallons, or is my fuel sensor so much off?
beammmer
D
NOLa
2019 JL two-door, 2017 X5, 1973 2002
Owners Manual say 17.5 for two door. Sorry didn't pay attention if you had four door.
Don
Rubicon_LA
Rubicon_LA
Los Angeles
2018 JLU Rubicon
My sticker says 21.5 gallons. and the specs I found on the Jeep web site say 21.5
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Two Door Models 17.5 Gallons 66 Liters
Four Door Models 21.5 Gallons 81 Liters
2019 Manual - Technical Specifications, p. 535
Yea that’s what it SHOULD be. The question is, if you run it completely dry, how much will it hold?
Rubicon_LA
Rubicon_LA
Los Angeles
2018 JLU Rubicon
You should probably have extra 1-1.5 gallons if you run completely dry. But not like almost 4 gallons that I am missing.
I mean 1 gallon here or there of reserve like BMWs have is understandable. But I have a hard time believing that my JLU has almost 4 gallons reserve.
robaw
Rob
Iowa
Like others, I have the same experience as you. If I drive until the gauge says it's pretty much completely empty, I still can only get a little over 18 gallons maybe in it.
Rubicon_LA
Rubicon_LA
Los Angeles
2018 JLU Rubicon
So, are we been lied by Jeep on this? And our tanks are actually much less than advertised?
Chocolate Thunder
Jeremy
Every highway vehicle has a reserve amount of fuel after the indicator says you are completely empty. Exactly how much reserve fuel is left when you hit E varies between manufacturer and model. Typically it’s at least 2 gallons or more.
I drove almost 50 miles without running out after the my DTE said I was dry. I don’t remember the exact amount I was able to fill but I think it was just under 21 gallons. That would make the reserve about 3 gallons or so on the 21 gallon JLU tank. So about 18 is the most you would normally be able to fill unless you ran it really low far beyond when it says it’s empty.
Rubicon_LA
Rubicon_LA
Los Angeles
2018 JLU Rubicon
If the reserve is that big then it makes sense. I didn't want to experiment and get stalled on a freeway somewhere, but I didn't expect a reserve on JLU to be 3 gallons or more.
Chocolate Thunder
Jeremy
I did the dirty work so you didn’t have to. Lol.
There was a thread a while back that got very contentious about this subject. The thread poster ran out of gas and got attacked repeatedly as being a reckless moron who endangered the lives of others by doing so. I believe it got closed and/or deleted after personal attacks and flaming.
