mgroeger
- Mike
- Feb 1, 2018
- Hurricane, UT
- 2021 JLUR 2.0T, 1991 YJ rock crawler
- Occupation
- I make microchips for a living.
- Vehicle Showcase
- 1
Thanks for all the responses. Unfortunately thread got hijacked a bit and I'm still not sure what I should do if I get the service axle locker system light and I'm in the middle of the desert. It looks like the worst case is I can still drive out with one of the axles locked. Would disconnecting the electronics to the diffs allow the axle to unlock so it could be driven on pavement? If I get the service axle locker system message and I don't activate the locker switch, can I drive the Jeep in 2H,4H and 4L without fear the lockers will self engage? If the dealer can't get me in for service or I'm waiting for parts, can I still drive the Jeep and use 4H and 4L if I don't activate the lockers? As you can see I'm confused as to how the sensor and activator interact in the diff.
The safest thing you can do when you start to get the axle locker fail warning on your dash is go out to the rear diff and unplug the harness from it. It will take about 30 seconds to do this. You will not be able to use either locker at that point BUT they also will not be able to completely flake out and engage on their own.
Then get your butt to a dealer to have it fixed. You're over thinking this.
In normal operation you can use just the rear or the rear and front together. You can never use just the front, so that option is never on the table for a stock Rubi.
I'd be happy to chat if you want more info. Just PM me and I'll give you my cell number.
