- Matt
- Oct 16, 2016
- CA
- Website
- www.gorancho.com
- 2013 JKU
So you lifted your Jeep Wrangler JL and love it, but the ride feels a bit off and it's wandering all over the place. How do you get that original ride back? Follow along as Dr. Deathwobble explains how Rancho control arm geometry correction brackets help gets your Wrangler back to factory spec. Easy to install, the part number for for the Jeep JL it is RS62118B. Enjoy!
Rancho® Jeep® JL Geometry Correction Brackets deliver perfect fit, finish and performance. These next-level Rancho Jeep JL Geometry Correction Brackets keep the control arms at factory angles to deflect road harshness, reduce brake dive and allow for proper caster angle after the addition of an aftermarket lift kit…maximizing the performance of your Jeep Wrangler JL. This NEW bracket fits Jeeps running lift kits from 2 - 4.5-inches utilizing our unique 3-hole upper control arm locator. Rancho engineering fit and finish delivers a one-piece welded design that will bolt-up directly to the factory locations out of the box, saving you time and aggravation.
- Compatible with 2 door, 4 door, non-Rubicon, and Rubicon Models
- Works on 2 - 4.5-inch lift kits that utilize factory upper and lower control arms
- Corrects control arm alignment geometry to factory specs eliminating the need for adjustable control arms or cam bolts for caster correction
- Fixed adjustment location for each height with an option for additional caster if needed
- One-piece welded design with a durable, black power-coated finish
- No assembly required! Out of box and on to your Jeep…an easy DIY project!
- Installs easily – 100-percent bolt-on system and detailed, full-color installation guide included!
